sansanjikikut
- Sep 26, 2015
Nothing mentioned about Face ID also. First time in 3 years. Not that it matters but
Nothing mentioned about Face ID also. First time in 3 years. Not that it matters but![]()
iPhone 12 mini/ 12 - 4GB RAM
iPhone 12 Pro/ 12 Pro Max - 6GB RAM
Gg, wanted to get 12 cause maybe there’s an increase in ram from the 11 pro max. Looks like I’m skipping the upgrade this year.
Tbf my iPhone 8 still working well
I am thinking should I change to 12 or 12 mini?
How do the MagSafe wireless charging works? Is it really wireless?![]()
Is it wasted if buy 5G iPhone but subscribe to 4G ?
Then again, is it a waste to pay extra for half baked 5G line?
Thanks
its just like the traditional wireless charging "pad"
instead of the "pad" stays on the table, now the "pad" is magnetically attached to the phone. so u can use it while charging
no need to remove from wireless charging "pad", then put it back again to resume charging.
so its like cable charging but magnetic wireless![]()
But any noticeable difference between these two ?
Thanks
Does anyone know whether the 12 Pro ultra wide camera is AF enabled? Any macro capability?
12 v 12 pro (128gb) - difference is like $400 including cost differential applecare. My main concern is the extra 2gb ram. Will 4gb be enough for casual user or is 6gb like a must have for future proofing?
The extra 2gb won’t make much difference.12 v 12 pro (128gb) - difference is like $400 including cost differential applecare. My main concern is the extra 2gb ram. Will 4gb be enough for casual user or is 6gb like a must have for future proofing?
If using the same storage for comparison
12Pro (128Gb)- $1649
12 (128Gb) - $1369
Difference is $280
https://www.apple.com/sg/shop/buy-iphone/iphone-12/6.1-inch-display-128gb-blue
the RAM is a surprised.
iPhone X (from 3 years ago) was on 3GB.
iPhone 11 Pro (last year) was on 4GB.
this year flagship model gets 6GB.
perhaps the ML stuffs need more RAM~?
You are using iOS not android
