iPad Air 2020 Discussions
Is 64GB storage good enough for studies?
Posted from PCWX using ONEPLUS A6000
Depends on your usage. Jotting down notes, some textbooks and apps, 64GB is ok. If you want to store games and videos then it can start to get a bit tight.
Anyone got any case? I m thinking if screen protector is same 11inch ipad pro?
Screen protector SHOULD be the same as 11" iPad Pro. However camera location may have slight difference, so need to make sure the cutout can fit.
Case need to ensure that there is a cutout for the fingerprint reader, so old cases will not work.
hwz_zx
for those interested. there's a $100 voucher off $800 in lazada for citibank payment. Voucher @ iphone 12 preorder page.
Just used it to check-out for ipad air. Limited variation left though.
s0tong
Thanks! Which color u managed to cart out?
It's_Not_Me
Think only for Laz Citi Card. Try just now but voucher cannot apply with other citi card :(
s0tong
Ya I expect 11.11 gonna have another promo up with all the colors available.. I also tried citi rewards the promo worked. But end up stuck with purchasing from apple.
Now all 23rd oct store stocks like no more. Hope more stocks incoming!
Pesantkie
Thanks! Honestly still thinking of which to get.
Does iCloud Drive take up local storage space if documents from icloud drive not downloaded?
Also since iPad Air has USB-C, I can actually store my documents on an external harddrive right (as a form of backup)?
s0tong
If for studies why not the pro 128gb 11"? IMO 64gb is for leisure use..
Pesantkie
Yes honestly considered that but the ipad is only for note taking and stuff. I will still get a laptop.
