iPhone 12 Series
how to backup my iphone 7 to this iphone 12? is all the data (including whatsapp, wechat etc) able to transfer over ?
These days you don't even need to back it up. After you sign in on your new iPhone they will give you an option to move all your data from your old iPhone, then it will connect and transfer over Wifi automatically
ekardo
but I got friends telling me their whatsapp didnt get transfer over...did they do a wrong step somewhere?
many told me just put the 2 phone (old and the new) together, and they will auto prompt to move everything over...is it really everything ?
sorry, I am bit kiasi cos 1 wrong step means 2hr of redo
cutebeng
Hi, anyone ordered at Challenger store? Can confirm if able to order there or at online only?
Snoweagle
Huh put the 2 phones together? No such logic. I’ve been transferring all my data over every year to the new phone and all gets transferred over as they are including whatsapp.
All you need to do is backup your old phone, plug in the new phone, go to the finder (if you’re using Mac) and restore your old phone’s backup to the new phone.
ecneret_eel
we share the exact same concerns and considerations
i’m on XS btw
Haha I'm also thinking between the Mini and Pro Max. Not into the unwieldy size of the Pro Max, but that camera that supposedly take better low light photos is quite enticing..esp when almost all indoor shots = low light.
Waiting to see camera comparison between Mini and Pro Max.
For device to device migration, see here: https://support.apple.com/en-sg/HT210216#migration
Available on iOS 12.4 onwards
Everything should be transferred over, including whatsapp data. Don't open whatsapp on your old phone after transfer is done or some messages will go to the old phone instead of the new phone. If whatsapp asks to reverify on the new phone, follow the instructions and everything should be ok.
KingOfSbw
Some bro mentioned need another paid tool to transfer over whatsapp stuff
Sent from Samsung SM-G985F using GAGT
*adiBOY
Now data migration is pretty easy and simple. Just put your old iPhone beside the new iPhone and let the data transfer between them wirelessly. Everything will be be transferred over.
daylight
use e Move to iOS app
https://support.apple.com/en-sg/HT201196
for WhatsApp u need a paid tool to do it.
what paid tool is reliable to migrate whatsapp ??
TrueBeliever_jh
so i jus transfer my sim card over first.. and then sync from my old phone~?
i used to backup to iTunes and restore from there.
working fine. jus need to setup ApplePay again.
bbbbbw
Was considering between 12 pro and 12 mini and I missed the 12 pro singtel pre registration
*adiBOY
Yes transfer SIM card over first. At the set up screen, options will be given whether to transfer data from old iPhone. Select that and migration will start upon pairing with old iPhone.
neeteshkurup
Will night mode ever make it to iPhone 11 Pro non main cameras?
Don't think so they will jeopardize their new phones even if the hardware of the 11 series is capable of it.
You can try NeuralCam. It gives pretty good results with the Ultra wide angle on the 11 series, though takes significantly longer.
Sent from Samsung SM-N986B using GAGT
