GoPro Hero 9 Black
hmsweethm
I got tempered glass protector from Amazon.
It makes the touchscreen becomes extremely insensitive.
So take note of this brand....
Not sure if all gopro 9 touchscreen will be insensitive with tempered glass protector.
hmsweethm
Got the snap mount with lanyard package.
Really very strong magnets....
Shutterfly
Are you planning to mount it on your chest and walk? If so, would like to see a sample footage to see how steady this will be when used with GoPro Hero 9. Thanks!
hellhole
i don't like these magnet mounts.. they can rust over time... i know that its coated and stuff.. but i have seen so many type of magnet mount type that rust...
hmsweethm
yup. Plan to do that on wkend.
Will post footage.
Discovered that with the silicon case on, the cam cannot be fully flip flat fully cos of this flap on the snap mount.
Initially when trying to install the gopro to the mount is very tight to slot in the “teeth” into each other. After breaking the “hymen”, it’s easier to take it off n on.
Ya probably if go into sea will make it rust.
By then see how.
Shutterfly
Video shows i switched from snap mount on the gopro 3way to the snap mount chest.
The magnet is tough. Pretty difficult to remove.
I think it is pretty good. So it is hard to detach? Say you walk a while and want to take it out for a snap at different angle.
hmsweethm
It’s difficult to detach. Need to be used to it. From my video, u can feel i took a while to remove.
Pros and cons. If it’s too easy to detach, it will be easily knock off.
There’re 2 flaps which previously i mentioned that block silicon case.
That’s where your fingers go to get the grip.
Something i feel gopro can improve on which is the time warp.
When i attach the gopro on my chest, using iphone remote control the cam.
For time warp, u can start/stop the normal speed.
On the regular handheld pod, u can easily access the touch screen to do that.
But when i attach to the snap mount on my chest, i cant access the gopro touchscreen.
Relying on iphone gopro app, i cannot find the control to do that.
Thus attaching to chest and walk around is only for taking normal video.
There’s 1 more observation on the snap mount, which i will show with pics later.
Shutterfly
Ok.. Thanks!
Shutterfly
Wah.. Quite a few accessories out of stock on the GoPro website like the Magnetic Swivel Clip and battery.
Shutterfly
Is there a grip that can remotely control a GoPro, something like a DJI OM 4 for the smartphone?
Shutterfly
For those who ordered Hero 9 online in Singapore
, how fast can we get the camera? Also is it worthwhile to get the bundle deal?
Thanks.
LPPLKPKB
For those who want to buy Heo 9 Max Lens Mod, the thing is damn tight to lock on, need to use a bit of force first time locking onto the camera.
