iPhone 12 Series
Icterine
Buy all. Then return the one you don’t like. Or wait until this Friday go molest the phones and decide.
Dunno whether Apple is even opening up their stores for hands on session this Friday. They disabled online booking since 12AM today.
ragnarok95
Senior Moderator
Senior Moderator
Buy blue or grey, once you slap on a cover hard to tell. Even the camera cutout there you think everyone can tell what color it is??? Hard i tell you.
athenodorus
Scare blue difficult to match case only....
i'm slapping it with the baltic blue leather case. it'll be full set with my blue apple watch with blue solo loop and blue catalyst case for my airpods pro.:o
ragnarok95
Senior Moderator
Senior Moderator
Friday... busy day for shops like RWM/WM/MS/KA etc.. they will sure have stocks of all colors. Can go to their shops to take a look.
ragnarok95
Senior Moderator
Senior Moderator
why hard? i'm slapping it with the baltic blue leather case. it'll be full set with my blue apple watch with blue solo loop and blue catalyst case for my airpods pro.:o
Also match with monday cause usually monday blue. :eek: :o :o
FinalNitro
Anyone can share more about the open box fee or restocking fee? For returns.
Is it specific to iPhone/iPad? Cause don't remember encountering it for my Airpods or Watch
SESE75
Oh cool, better to see the phones in person 1st.
Looking at those 12 and 12 pro unboxing in YouTube, concluded that pro will have fingerprints on the flat edges if you use w/out casing.
xenocide
This alleged video demonstrates MagSafe Qi Wireless charging for both Android and iPhone 11 Pro. Both charged at the same rate at ~5.14W.
https://youtu.be/3tbmrbwDmCY
as adiboy explained, if you see the video properly, the iphone is charging from 65%, thus full power i.e. 15W is not "needed"
secondly, propably also becos its iphone 11 and there isnt magsafe NFC to "recognise" as magsafe device, thus max also 7.5W
as for the android, i think the non magsafe rule applies? thus also low wattage?
correct me if i'm wrong
bedlamite
12 pro 4g is 1 hr more than 11 pro. That’s not bad
4G test is good, considering the screen is brighter than last year's (I think)
5G cmi lah. It's unfortunate Apple bowed to carrier pressure (cuz consumers certainly weren't clamouring for 5G) to get this feature into this year's lineup. Shoulda got that TouchID back instead grrrr. Under-display, in-power button, whatever. This stuff isn't new, c'mon
Icterine
Yes both the 12 and 12 Pro are fingerprint magnets, just that one is at the glass back and the other is along the stainless steel sides. Both require a case or a bumper for real world use. I usually go for ultra slim matte finish rubber cases.
KeYoKe
Gonna disable 5g when i get it though till 5g widely rollout then turn on
Posted from PCWX using Pixel 5 Sorta Sage
