Any Bros can help check? Thanks
Think everyone installed already. Unless they working in Apple and can find a 256 set to check
Btw.. if u using google photos, lower resolution photos will get uploaded.
I read the return policy that there's a 25% fee for opened boxes? Any idea if that's strictly enforced?I don't think it's an OS problem. Google photos will display all your saved photos on your iOS device. You can call or initiate replacement online or through your iOS device (Apple store app). I don't think they allow replacement. You will have to return the device for refund and repurchase. Correct me if I am wrong. I would advise you to just book a reservation for a new phone then when the staff is attending to you, just return the current device with the staff that's attending to you. Apple's refund process is really quick.
Go-to your iphone photos app. Click on Album tab. At the bottom there is a Recently deleted option. That's your "Recycle Bin" I believe it will house deleted photos within 40 days of deletion.
Sent from OnePlus GM1910 using GAGT
How to delete iCloud backups on your iPhone or iPad
Launch the Settings app on your iPhone or iPad.
Tap on your Apple ID right at the top. It should be the name you used to sign up for an Apple ID.
Tap on iCloud.
Tap Manage Storage under iCloud.
Tap Backup.
Tap the device whose backup you want to delete.
Tap Delete Backup at the bottom.
Tap Turn Off & Delete.
What made you decide to move from a 11 Pro to 12 Pro...?Today 3rd day with the 12 pro, batt life quite significantly poorer than 11 pro. Abit disappointed but no choice, buy already gotta suck it up. See how the pro max performs before deciding next step
interesting, you just walked into A Lab to buy?
The SingPass SafeEntry widget is quite excellent
I came from samsung s20+ exynos, i find ip12 pro batt life much better at least it can last me 1 full day (near 12am) without charging for the 1st 2 daysToday 3rd day with the 12 pro, batt life quite significantly poorer than 11 pro. Abit disappointed but no choice, buy already gotta suck it up. See how the pro max performs before deciding next step
Heading out later so I’ll see what works the fastest, back tap to open up Control Center-> open QR scanner or tap power button and swipe right to open up safeentry widgetYes its nice, i use back tap as well
I'm also having significant issues with iCloud and photos (some user issues, some comp issues and just plain bad luck). Also, coming from a 6.5" android phone the 6.1 screen takes a bit getting used to. Faceid also a bit hit or miss..
I would say for the average casual user like me or older folks, probably a larger android phone is better buy.
However despite not being any good at taking photos, I'm surprised by the good quality of the shots I took of family etc. Definitely a big unexpected plus for me.
Ah ok got itdun use e QR scanner. it won’t be able to save yr particulars since it opens up a private Safari tab. just use e camera app.
Had tried to use Google photos as a primary backup before, however to experience was not too favorable in iOS at least.
Paid for iCloud storage everything worked seamlessly.
2 cons here:
You are stuck with Apple eco system.
Your main photo album can be shared to other family members like google photos does.
