iPhone 12 Series
cnt
those who sold their 11 to upgrade to 12, where to sell to get most value?
my 11 pro max still got 100% battery health, in perfect condition 0 scratches etc even back got screen protector. but usually sell to those 2nd hand shops etc they take in at quite low price right?
Try carousell
ScVandMagix
Usually max battery life will be better than pro one
Bigger screen but larger battery also mah
it will defo be better than ip12/ip12p but I don't think it will be better than ip11pm.
for my usage pattern, only ip11pm can allow me to go thru the day without charging... if it's worse than ip11pm, then I won't be getting it liao...
SESE75
Battery life really depends on usage
cnt
IPhone XR and 11 were best sellers. Price is important factor
bedlamite
The Pro Max will have a much bigger battery. Don’t think the screen size will affect battery life too much, Apple isn’t doing anything crazy here like a 4K screen or 120hz
I am a little disappointed by battery performance on the Pro but it’s not like I was expecting miracles going in, after all isn’t the battery like 2800 mAh or something? It just means I need to bring a charger into the office again. That said, I pray for those of you waiting for the Mini. That one afternoon confirm flat.
bbbbbw
I transfer data from XS to 12 pro with both phones side by side. the backup from XS is showing on my 12 pro under iCloud storage and not able to delete it to free up space on iCloud storage.
If I log out Apple ID on XS and reset the phone to sell, it should be safe right. I also noticed on fb app, my 12 pro is known as “ipad” under recognised list of devices. Previously my XS was known as XS on fb app.
ragnarok95
Senior Moderator
Senior Moderator
Seems like 12pro battery life isn’t good. Uravgcon also report poorer battery life on his 12 pro.
bedlamite
Chillling on my sofa, decided to take the phone out of its case and use it naked for a bit. Such an exquisitely made handset. The way the rounded corners fit into your palm, the way the matte back contrasts with the shiny edges.
porky_88
Oh you mean 5.5 down to 5.4
you cannot just compare it this way. 5.5" and 5.4" is diagonal
but 7+ aspect ratio is 16:9. 12 mini aspect ration is 19.5:9
most people perceive size from width. and width wise there is a huge relative difference.
imho best way to gauge size of 12 mini is that it will be slightly smaller than iphone 7 but screen width will be almost the same and 12mini will have a taller display. couple with the flatter side of the 12mini.. the in hand feel should be very similar to iphone 7
the actual physical width between 11pro and 12pro is 0.1mm more on 12pro. but it feels bigger in the hand due to the flat sides...
