jq75
- Dec 5, 2000
Can it done wirelessly between the 2 phones?
Can put side by side and transfer ma
For those who are curious cat like me. Lightning cable is faster despite it being on the pathetic usb 2.0 tech.
Scenario, I have 100gb used on my 256gb units.
Placing them side by side, i've tested usbc-lightning cable restore from PC to new ip12pro, and then for comparison after i wiped my ip11pro i tried wirelessly transfer from ip12pro to ip11pro
cable took 1 hr 4 mins
wireless took 1 hr 30 mins.
both 100% battery
connected to 5Ghz wifi6 less than 1 meter away from router.
both phones tested on speedtest to clock over 880-900+mbps transfer rate, in case someone is wondering about my router's performance.
I was expecting wifi transfer to be faster, but no. I have no conclusion to why but to suspect wifi might have poorer overhead in transferring smaller files.
Think along ssd/hdd benchmarking or copying, with more smaller files the throughput suffers badly.
Hi,
May I know is there a method that I can start the phone as a new phone.
Then sync only the photos from old phone to new 12 pro ?
I used lightning - usb C cable from PC to iPhone.
iCloud. u can turn off everything except e photos. of course u need enough space on iCloud. or I guess using Google Photos/other photo backup services wud work.
Actually you can set up as new phone and just use back the same account. All photos will still be synced.
For example you set up a new iPad, all photos will be sync
Yes sir! I’m at my pc day in day out. Has iTunes sync on plug in. So for me my backup never aged more than a day.this set up needs pc to be connected to one of the phone?
Hi. May I know if the wireless data transfer between 2 iPhones will also transfer all WhatsApp chat records and photos in WhatsApp? Do I have to back up the WhatsApp data in the old phone to iCloud first?
Thank you.
both 100% battery
