I think it is pretty good. So it is hard to detach? Say you walk a while and want to take it out for a snap at different angle.
It’s difficult to detach. Need to be used to it. From my video, u can feel i took a while to remove.
Pros and cons. If it’s too easy to detach, it will be easily knock off.
There’re 2 flaps which previously i mentioned that block silicon case.
That’s where your fingers go to get the grip.
Something i feel gopro can improve on which is the time warp.
When i attach the gopro on my chest, using iphone remote control the cam.
For time warp, u can start/stop the normal speed.
On the regular handheld pod, u can easily access the touch screen to do that.
But when i attach to the snap mount on my chest, i cant access the gopro touchscreen.
Relying on iphone gopro app, i cannot find the control to do that.
Thus attaching to chest and walk around is only for taking normal video.
There’s 1 more observation on the snap mount, which i will show with pics later.
