Google Pixel 5
mightythor
Hi, for those who ordered the Pixel 5 from Clove and Amazon UK - what are the differences in the set that comes to you? Are they also UK sets with 3-pin plugs, for example? Warranty coverage I assume is within UK?
Just got mine from amazon UK too! Think we all same batch!
KeYoKe
Same uk unlock p5. 3 pin plug and yup warranty only in uk
Posted from PCWX using Pixel 5 Sorta Sage
limmk
Just to add, if you buy from us and taiwan, the power adapter comes with
Australia comes with
MU7X2_GEO_AU
So you will need universal adapter
If you own previous pixel, just use back the the 18w power adapter
mightythor
Thanks everyone. Clove had a delay in the Sage Green colour so I was considering Amazon Uk, just wasn't sure if I would be getting the UK set or from another country from Europe. Thanks for all your help.
ParkJinYoung
Personally I would suggest to get from Amazon UK
Sent from Google PIXEL 2 XL using GAGT
garychengjw
KeYoKe
Yes for GST.
Amazon is all in.
Clove UK separately charged by courier.
Google to forwarder, you need to declare the value. (in case lost of package for compensation etc...)
My amazon got conversion charges too. Add up abt 1030
xonix
Anybody here who owns both 4a & 5 ?
How big is the difference in the image processing time ?
Kiasuman
Yours no currency conversion fee?
Nope don't have, at payment/billing part, need to ensure they charge your CC at the base currency (pounds) rather than convert. Then your CC will convert rather than Amazon's conversion (crazy high fees).
