OnePlus 8T
ranmaru1987
I'm on IN KB05DA firmware...any noticeable or significant difference vs AA? Worth the effort and risk to change to AA? Seeing ranmaru keep wanting to go on AA firmware makes me feel like DA is cui or something wrong, lol
Just download the firmware and manual update can already.. no risk de..
Sent from OnePlus 8T using GAGT
Aikon
I couldn't get it working under the DA firmware.
Just tried it with the AA.
Is the global firmware supporting Volte out of the box? I only downloaded Logkit to enable it. Then *#800#.
Function switch VOLTE and VOWifi. Then reboot. No further steps necessary.
Made phone calls... Still maintained as 4G๐Ÿ˜๐Ÿ˜„๐Ÿ˜ƒ๐Ÿ˜€
Loser
Which network are you under bro?
eric5001
Made phone calls... Still maintained as 4G����
Mind share the logkit here?
Sent from OnePlus GM1900 using GAGT
KeYoKe
Dont need too happy. Not working after ota update lol
Got a reviewer also say after update gone
Posted from PCWX using KB2000
Aikon
The difference between my phone and bro keyoke is my firmware is global before the update. I flashed from India to global. I got a prompt to update but I'm busy setting up the phone so I ignored it.
Now I don't think I will update liao.
Prefer to have VOLTE.
cljinsg
If that's a simple steps, just repeat lor. OnePlus has an A+ update frequency historically? 5T users beg to differ lol
badboy83
I just received the set,is it good to flash global rom? Thinking to settle the rom,before start use...
lousydrinker
OP8T ready stocks and available now, local and export set. Come join the club.
Can share why u love it more than S20 FE? Lol
The green color with glossy look is refeshing. Bezel is mininal and looks quite uniform all over unlike S20 FE. I dun like the matte finishing on S20 FE. The screen looks good on OP8T too as compared to my OP5T and S10+. Might even look better than S20 FE imo
Posted from PCWX using SM-G975F
KeYoKe
I recommend u to flash bro
I also feel it looks better then s20fe, cos of the black camera cutout instead of the silverish one on fe, and the fe camera cutout quite intrusive (lower in position)
badboy83
Bro,I first time use op, anything have to take note before and during flash the global rom..thanks for your advise...
KeYoKe
Nothing much. Just make sure got sufficient battery charge
sad .. any other way to enable it?
shouldn't have update it...
No other way. Only can wait for oppo sg to work with telco to enable it
Posted from PCWX using Oneplus 8T Lunar Silver
KeYoKe
So far, love the haptics, the screen and the silver color of the phone
