Starhub Giga
SibehHL
which better deal as looking one too? low usage user. thanks.
Personally I prefer to stay on Singtel or Starhub network; will not consider M1 network since the areas I frequent very often have weak to no data connections even though the 4g signal shows full bar.
$10 plans:
Giga 6GB with monthly rollover
CMLink 5GB with cross border data sharing
Vivifi 6GB unlimited
Suggest you try them out for yourself since all are without contract, port in and out as you wish.
Angtehkor
I really wonder the 2 mobile numbers 88868858 and 88868588 that someone selling at carousell is from giga. So many 8s total six 8s. The most 8 I see at giga app only five 8s which is three 8s in front and the other two 8s in middle or behind. I keep on searching on giga app for six 8s mobile number despite I already have a very swee mobile number 888666*8 activate today 1 November at 00.00am. I email giga to ask about it but still no reply from them.
crystalnox
Went to China Mobile for their $15/5GB with 6months/$10 rebate; will probably stay with them after the promotion because of the strong & stable connections on Singtel network.
CMLink updated their plans, 5GB/$10 as permanent price now. Remember to switch once your rebate ends.
decibels
Hello 88866638 :s13:
I got 1 even more swee than ur number also not so haolian
Angtehkor
Now giga the signal not very good. Whole day only 3 bars don't have 4 bars. Maybe too many subscribers that why the signal is affected
SibehHL
Don't let me stop anyone from collecting "lucky" numbers... I can see it's an addictive hobby especially with a low starting cost of $10 monthly :o
But can someone enlighten me on the fixation with multiple 8 & 6 digits? Does it really change anyone's life?
decibels
I was a very suay guy, my hp used to be 8217**36, play 4d/toto/mj always tio jiak. That time my wife almost left me for no reason.
Until recently I got a sibei swee num from M1, 87788**8, my luck change man. My wife came back to me for no reason. 4d always tio like 1st and 2nd prize. Play mj always win 3 ka.
Golden number is really important
SibehHL
Ok, giga... Here I come
Aion99
Left only not so swee numbers, when will giga open new numbers range? Currently is 8886xxxx
CarManiac
I just switched from Singtel combo plan to Giga $10 plan. I do noticed the speed of doing SafeEntry check-in and out is so much slower.
I have a question. I have 3 lines under Giga, each SIM card on different phone, how do I use the Giga App and each one show the number for each phone? When I set the default number, all phones show the same default.
Kiwi8
Deluxe Member
I think same account will just display the same default. So if your lines are under the same account it will not be possible to make the app display different default line for each phone.
CarManiac
Thanks! Starhub should consider changing their app to allow display of data usage for all lines in a single page so that it is easier for subscribers with multiple lines to monitor usage.
