OnePlus 8T
jtec14
Yes bro. Volte tweak cant work.on A11. Requires root to activate.
I do not want to root and risk the security of our device. So no choice can only live with it
Posted from PCWX using S20FE Cloud White
Yes PDC doesn't work with A11, so we are stuck at the moment without VOLTE.
Thank you both! Sian 1/2 liao... still thinking to see any good deals on 11.11
ranmaru1987
Got try fanny in mlbb or not? Can the touch screen keep up with your touch input?:s11:
Because my only problem with my 7T is the lousy touch sampling rate when playing heroes that need fast hand speed. like the hero can't keep up with my touch...
Bro.. I know wats your issue already.. u got turn on 3 finger ss is it?
Sent from OnePlus 8T using GAGT
Loser
Wa nice catch bro, that one very hard to know. But ya I already turned it off when I trying to optimize all other settings and network factors. :)
In the end can only conclude the touch latency cmi on 7T. :(
ranmaru1987
Haha.. not cmi la.. 7t iirc is 180hz also not bad ma..
mamboeidos
Msg seller n seem to be China seller cos I ask a he reply b like will the unit be flash to global rom anot.
Just tell me limited edition, a few stock, wan to buy?
Posted from PCWX using SM-N960F
KeYoKe
Strongly suspect is china rom as not released in other countries
mamboeidos
Ya lor. Othan than China no other place release mean no global rom? Cannot use normal 8t rom to flash right?
Cos I noon in this flashing thing. But read previously some of u said is slightly diff rom de.
China n goblal rom wats the diff ah? No google only?
KeYoKe
Ya no google and some stuffs like telco bands and stuffs different
Rom cfm different. cyberpunk rom got cyberpunk theme
Aikon
Hi, so i gotten my set today.
the firm ware is oxygen os 11.0.1.2.KB05DA
i want to flash to global AA.
so i just follow this guide and download the AA version or IN version?
https://forum.xda-developers.com/oneplus-8t/how-to/op8t-unbrick-tool-to-restore-device-to-t4180837
Yes, KB05AA is the global version. The other 2 are Europe and India rom.
If you want volte, don't update to the latest firmware. For me, There's not a whole lot of difference with the latest firmware update.
