GANGSTERKIA
- Oct 6, 2010
Is there any promo for progressive lens this month?
I'm planning to get a new pair of progressive lens.
Hello, hello, this is a little off. But is there any shops that offers 'find a spec that match you' like of service? I had tried Zoff and Owndays but wanted someone to tell me, which frame suit me kind, want to be more yandao a bit. Thanks thanks.
Read about computer lens that reduce blue light, and it seems Zeiss lens is good? Currently not wearing specs so I dunno much.
Approximately how much would a pair cost and from where?
Thanks!
Hi, I would like to get advice on getting new lens.
I was specifically looking for one that blocks blue light and was newly introduced to blue uv capture.
Was eventually suggested to consider 1.67 blue uv crizal sapphire which I supposed should mean blue uv capture + sapphire coating.
I did a little research on crizal lens and saw one that says blue uv capture + prevencia coating offers the ultimate protection for blocking harmful blue light.
Can anyone here please enlighten? Which is the better option?
Honestly, all blue filter lenses are about the same to me. If you want to have a pair for computer, i would recommend lenses such as Crizal Eyezen/Hoya Sync. Comes with blue light and a slightly lower power at the bottom to relax your eyes when you are looking at your phone/computer etc
The lenses itself start from about $280 onwards. If it is just a normal blue filter lenses, prices start from about $180. Frame wise, depends on the frame you pick
Can i know how much roughly the price for zeiss or hoya lens for 1.67 index? No need blue light filter or photochromatic one, just normal coating will do. Want to gauge how much budget do i need if want to make new spec with this lens. Thanks.
I made tag heuer with zeiss lens around 5-6 years ago for about 800$. But quite disappointed because the rubber is fall apart after 2 years warranty over.
Now just wear owndays. Thinking to change to better quality lens.
Hi Gangsterkia,
Do you have any places to recommend if I would like to get a new pair of spectacles: Lindberg frame (Allan 50) + Transitions (w blue light or drive protection)?
Degree is 200+.. Hoping to keep it within 900 if possible.. Thank you!
Hi all,
May I know what is the reasonable price to pay for a Zeiss progressive individual 2(1.74) for eye condition below:
1) 1300 degree short sight for both eyes.
2) a long sighted that cannot read font 8 from normal reading distance.
3) got astigmatism
Furthermore, I am told this lens will auto include blue protect. correct?
Hi Gangsterkia,
Thanks for your time and helpful reply.
For Zeiss progressive lens, if I say the improvement for comfort to user from "Pure" to "Plus" is given a value of 5, what value from 0 to 10, would you give for upgrade from "Plus" to "Individual 2"? 0 being no improvement and 10 mean a lot of improvement.
Also, could you name an alternate brand of same tier to "Individual 2" and what is the price for same case.
