Real International speed tests
What ISP are you testing on?
  • Total voters
    64
firesong
Deluxe Member
Dear all,
Our local ISPs advertise internet plans with fantastic numbers for us. However, as we all know, Singapore isn't a country where content is locally produced - a lot of content we consume come from overseas and hence are bottlenecked at the international exchanges.
Not everything is mirrored locally (it's impossible to download the whole of the internet, if you think about it), so more often than not we find our traffic going over the international pipes.
Thought of starting an initiative to collate some real-world speed tests over a period of time so that we can make an informed choice of ISPs for those who are planning to recontract or are looking for an ISP. This will be on a purely international traffic performance basis.
Remember: our local speed test results do not give us the real truth. Also, they are optimised traffic to the speed test servers, so again aren't very accurate representations.
As this effort depends on a large collaboration, I would suggest that we try and keep it to a fairly universal standard layout so that we can all have a pool of real results to compare. It's not about getting the fastest, but really about getting the best money for your buck. There is no point signing up for 2Gbps, 10Gbps, or even 1Gbps plans if our real speeds are much, much lower than that. Now with the economy getting worryingly bad, every dollar saved can be put to other expenses for the family!
As with anything, screenshots are appreciated so we can see real results. I would suggest that, given the nature of IP assignments these days, that you redact your IP address to protect yourself. But it is up to you.
As such:
1) State your ISP
2) State your plan
3) Date/Day/time of test - this is for statistical information.
4) Screenshots of tests with various countries.
5) I randomly selected the following servers: USA (Comcast San Francisco), Japan (Rakuten Tokyo), Canada (Bell Mobility, Vancouver, BC), UK (Jump Networks Ltd, London), Hong Kong (China Mobile), Thailand (AIS Fibre Bangkok), Malaysia (U Mobile, Kuala Lumpur), Australia (Optus, Melbourne), Korea (kdatacentre, Seoul)
6) Any comments you may wish to add.
Speed test servers from www.speedtest.net. The native Windows app does not allow you to select most other servers to do international tests. Feel free to suggest new servers to test so we can get more optimal results.
Updates.
Revision 2.1:
Thanks to a massive contribution from fellow forumer @xiaofan and some tinkering, we've moved to using the command line interface to automate testing.
https://www.speedtest.net/apps/cli
For now, the tentative Linux/macOS shell script and Windows BAT file. It exports a file results-YYYYmmdd.csv, and we can open the file using the attached MS Excel File that automates the formatting process. Open it, go to Data -> Refresh. Select your exported CSV and it should automatically fill and format the data. Go to Alternate tab, copy/paste in HWZ. Done. :)
Server list is a random selection from around the globe.
Linux/macOS Version:
Code:
# csvspdt.sh
#!/bin/bash
# exports to YYYY/mm/results-YYYYmmdd.csv in subfolder.
mkdir -p ./results/`date +'%Y'`/`date +'%m'`
RS=./results/`date +'%Y'`/`date +'%m'`/results-`date +'%Y%m%d'`.csv
# Singtel
speedtest -fcsv -uMbps --output-header -s13623 > $RS
# ViewQuest SG
speedtest -fcsv -uMbps -s2054 >> $RS
# PT FirstMedia - Singapore
speedtest -fcsv -uMbps -s7556 >> $RS
# Comcast - Sacramento, CA
speedtest -fcsv -uMbps -s9436 >> $RS
# Spectrum - Los Angeles, CA
speedtest -fcsv -uMbps -s16974 >> $RS
# University of Texas, Austin - Austin, TX
speedtest -fcsv -uMbps -s16089 >> $RS
# Optus - Melbourne, AU
speedtest -fcsv -uMbps -s30932 >> $RS
# Misaka Network Inc - Tokyo, JP
speedtest -fcsv -uMbps -s44988 >> $RS
# SIMPLYCONNECT - Dar es Salaam
speedtest -fcsv -uMbps -s13902 >> $RS
# Celcom Axiata - Kuala Lumpur
speedtest -fcsv -uMbps -s4956 >> $RS
# Bell Mobility - Vancouver, BC
speedtest -fcsv -uMbps -s17402 >> $RS
# Telstra International - HK
speedtest -fcsv -uMbps -s44340 >> $RS
# ChinaTelecom 5G - Guangzhou, CN
speedtest -fcsv -uMbps -s27594 >> $RS
# ChinaTelecom - Shanghai, CN
speedtest -fcsv -uMbps -s3633 >> $RS
# ChinaUnicom - YunNam, CN
speedtest -fcsv -uMbps -s39012 >> $RS
Windows csvspdt.bat
Code:
@echo off
:: Create results subdirectory if it does not exist
if not exist "results\" mkdir results
:: Define the filename variable
set RS=.\results\results-%date:~10,4%%date:~4,2%%date:~7,2%.csv
:: Singtel
speedtest -fcsv -uMbps --output-header -s13623 > %RS%
:: ViewQuest SG
speedtest -fcsv -uMbps -s2054 >> %RS%
:: PT FirstMedia - Singapore
speedtest -fcsv -uMbps -s7556 >> %RS%
:: Comcast - Sacramento, CA
speedtest -fcsv -uMbps -s9436 >> %RS%
:: Spectrum - Los Angeles, CA
speedtest -fcsv -uMbps -s16974 >> %RS%
:: University of Texas, Austin - Austin, TX
speedtest -fcsv -uMbps -s16089 >> %RS%
:: Optus - Melbourne, AU
speedtest -fcsv -uMbps -s30932 >> %RS%
:: Misaka Network Inc - Tokyo, JP
speedtest -fcsv -uMbps -s44988 >> %RS%
:: SIMPLYCONNECT - Dar es Salaam
speedtest -fcsv -uMbps -s13902 >> %RS%
:: Celcom Axiata - Kuala Lumpur
speedtest -fcsv -uMbps -s4956 >> %RS%
:: Bell Mobility - Vancouver, BC
speedtest -fcsv -uMbps -s17402 >> %RS%
:: Telstra International - HK
speedtest -fcsv -uMbps -s44340 >> %RS%
:: ChinaTelecom 5G - Guangzhou, CN
speedtest -fcsv -uMbps -s27594 >> %RS%
:: ChinaTelecom - Shanghai, CN
speedtest -fcsv -uMbps -s3633 >> %RS%
:: ChinaUnicom - YunNam, CN
speedtest -fcsv -uMbps -s39012 >> %RS%
Link to Excel file: https://disk.yandex.com/i/VGCa8eMQvb1DBw , https://file.io/42mZP6Gf84DD
Edit log
- 16/3/22 Added China servers.
firesong
Deluxe Member
Singnet Fibre Broadband, 1Gbps plan
Tests done: Friday, 6 November, approx 8pm.
Comcast San Francisco, CA:
Rakuten Mobile, Tokyo:
Bell Mobility, Vancouver, BC:
Jump Networks Ltd, London:
China Mobile Hong Kong, HK:
AIS Fibre, Bangkok:
U Mobile, Kuala Lumpur:
Optus, Melbourne:
My observations: Speeds are no where near 1Gbps. Not even 300Mbps, imo. And just look at those pings. Is it any wonder that gaming and video conference calls lag so badly?
firesong
Deluxe Member
Added Korea, but it exceeded the limit of 8 images:
kdatacentre, Seoul:
yusoffb01
Show you best case scenario. 6 Nov, 8pm
Local speed 2GBps
Japan
California
Texas
Germany
London
South Korea
Russia
firesong
Deluxe Member
Lol I show u better speeds ******************
Please do. Nothing like real world proof, crowdsourced.
You left out your plan details. It looks like you're peered to a data centre?
yusoffb01
Yup. Amazon aws. So even best case scenario, actual speed overseas is less. 500mb plan is good compromise
firesong
Deluxe Member
Google cloud seems to be limited to gigabit
This is interesting,
Thanks for the theoretical best speeds. Good to know for companies who need to peer at the dc. :)
The pings remain insanely high though. And some speeds are lower than I expected - particularly, USA, South Korea, Europe. Says something about our routes.
miloaisdino
Optus, Melbourne:
singtel to Optus Melbourne is just pathetic. singtel cant even give decent throughput and latency to access their own subsidiary's network?! wow...
anyways, i seem to have much better throughput to this server that you (very weird..). im just testing from my phone over wifi ac so far,
maybe we could share our ip ranges too? mine is 121.7.xxx.xx
yusoffb01
anyways, i seem to have much better throughput to this server that you (weird..). im just testing from my phone over wifi ac so far,
Anywhere to Australia is pathetic since they don't have direct connection to many countries.
But we are lucky https://www.submarinecablemap.com/
miloaisdino
maybe u helped us saturate their peering port speed liao :D
anyway the cpu looks unusually high.. btw have you disabled spectre mitigation and other mitigations yet?
yusoffb01
maybe u helped us saturate singtels peering port speed liao :D
think its shared virtual cpu with many users
miloaisdino
maybe we should setup a smokeping server so we can monitor and see latencies constantly too
firesong
Deluxe Member
Yeah very weird. The difference is so stark. Mine is 121.6.x.x (took me quite some time to get this without being IP blocked. For a while I was in a really bad IP range.)
Those who do not know their geography might be impressed that Malaysia has wonderful connections to the world. :s13:
miloaisdino
can share the results to singtel local server too pls? this international speed looks abnormally low even for singtel..
miloaisdino
haha.. good luck getting to the node at KL! sg to kl alone is 8-15ms !!
anyways dk if this helps, but i use a mikrotik router, and I notice setting my mac address to a "known OUI" eg 48:8D:36 (arcadyan) might improve performance (not sure of its just a placebo :) ) i also occasionally tag my outgoing packets with dscp 46/48/56/34 for higher priority
firesong
Deluxe Member
Typically Singtel. -_- Disclaimer, I have two other active users so I can't kick them off. Shouldn't be this bad though.
firesong
Deluxe Member
That is highly unethical business practises just exposed right there!
Not using a Mikrotik for now since I decided to stick with my ERL3. But will KIV the info. =)
Normally speed test is not throttled by isp. What speed do you get if you download this.
https://drive.google.com/file/d/16vWW3wUxdtrsTs3Iu8iBl2Hn-5uRD5lA/view?usp=drivesdk
16-18MBps. Not fantastic. Yes I know the speeds are unthrottled. It was just a convenient tool for testing at various international servers without jumping from server to server, and a stark reality - that unthrottled and priority given, we are still getting poor pings and speeds on the international stage.
