honeydewmeme
- Oct 20, 2020
Any recommendations for hair treatment for dry hair with split ends?
Morris Motley Styling Treatment Balm - after they changed the packaging is it the same quality? I briefly remembered someone mentioned it's different now.
Any other recommendations along this line?
Got any volume mousse to recommend?
I used this brand Deveo Amino Kera Cream. Bought it from a hair salon. It have sweet floral smell so i kept applying to my hair after buying.Any recommendations for hair treatment for dry hair with split ends?
Its not what it use to be. They "meddle"with the formula.
Now lost its magic.
Went back to the original or the new formula?I have tried other alternatives but still go back to MM.
Still the best hair clay.
Go to a skin clinic and ask for a PRP treatment, plus what you are using right now as a regime. You will see drastic results.any hair tonic to recommend? I used to use Growell 5% Scalp Lotion but not sure if its working though
You may wish to consider using prestyler. To pull off center parting, it is not easy. Your face shape is important as well. But lets just focus on the styling products here. One gd option is seasalt spray (sss). You will need good volume / good hold to bring out the beauty of center parting.
1. Although you have thick hair, it doesn't necessarily mean volume. In fact, you need the boost from sss to build volume for you.
2. Furthermore, since you have fine hair, it comes w characteristics that do not allow you to hold styles well. So having a sss will help you ease the styling difficulty that you may face.
3. The main styling product (wax/clay) isn't really going to make a huge difference here. Matte or slight shine products should work ok in this case. Just get 1 w decent hold and not too heavy will do fine.
