Mai tu leow
- Jan 19, 2018
At least a 7-8. But take note, the higher your presbyopia power the more distortion you will have. Just that if you use a higher tier lens, it will be better.
A similar tier and cheaper would be the Mystyle V+ from Hoya. From my fitting experience, *fingers crossed* I had not remake/handled any dissatisfied customer who used Mystyle V+.
1.74 Mystyle v+ would cost 2600 with the blue control.
Or the next best option would be the essilor Xclusive lens. However only certain shops in Singapore can sell the lenses as a specific machine is needed to take some measurements.(not just the panto/wrap only). It would cost 2800 with the blue filter.
Many many thanks for this super useful info!!
