Circles.Life Discussion Thread
tankee531
You guys now just do a simple search. Circle life now offer unlimited calls and 100gb of data with roll over for 12 months at $18 each month. Too bad I port in too early I only got unlimited data until 30 June 2021 but no unlimited calls for me.
got fineprint
*Plan reverts to 20GB + 100 Mins for $18 after the 1st month.
Angtehkor
I entered the code but it doesn't show unlimited data. Only unlimited calls.
Angtehkor
Yes. Have you tried it yourself? Try entering into Circles Life checkout. It will not show unlimited data.
Yup I try just now it never show unlimited data only unlimited incoming and outgoing call. But the picture I post write 100gb data for 12 months leh. Why ah
Scuderia
What is the Circles Life managed speed for unlimited data after the first 100GB?
tuntun
Hi I was told from a friend that his old CL line is using starhub line. is it correct? Why did they move to m1 since starhub was better line connection. Are there any CL user under starhub lines?
Kiwi8
Deluxe Member
A most likely reason, StarHub lease more expensive than M1 lease.
007Mi6
These are all business decisions and at that point of time, Starhub could have met CL needs and requirements. When it is time to renew the supply, M1 could have come into the picture with different plans and CL would have different needs, such as VoLTE
tuntun
I see. So CL can use with faster clearer digital voice 4G voice (VoLTE)? which other VMNO cannot provide? I chatted with cl and they said not advise to ON it just leave it off...why? it doesn't related to data speed
joesph
I thought m1 all along. not the m1 Apple silicon chip
Sent from Samsung SM-G980F using GAGT
007Mi6
Well, did you ask CL why they advise to off VoLTE?
Jurong640
I think should be MyRepublic. Circles.life from the start is using M1. MyRepublic started using Starhub and use for around 2 years before changing to M1 this year 31 March.
