XiaoMi or Baseus Powerbank
GoodBetterBest
hi !
I think Xiaomi's powerbank are very good, from the internet feedback. What about Baseus ? Baseus also a good brand, right ?
In particular, I'm looking at these 2 PB and wonder which one I should buy.
Baseus: https://shopee.sg/BASEUS-Bipow-quic...harger-PowerBank-10000-mAh-i.10208.6302329583
- half the weight of the xiaomi one
- 14 days warranty
Xiaomi: https://shopee.sg/-FREE-Case-Xiaomi...ut-New-Dual-USB-Output-i.186022643.7519079359
- lower current for smart watch
- 1 year warranty (shop warranty)
Thanks for any advice in advance. Appreciated.
GoodBetterBest
both are good brands. I would prefer Xiaomi, they have low power output to charge watches.
agree with your point. But it's 2x the weight. Unfortunately, Baseus warranty is 14 days only.
It's good that I get confirmation that Baseus PB is ok. Thanks.
lohsenglte
hi !
- 14 days warranty
I would say Xiaomi is typically more reliable. Some baseus have significant QC issues, for example their 65W 30Ah (30000mAh) PB.
limpingsim98
the xiaomi does not support pd charging
Sent from Samsung SM-A705MN using GAGT
PD. Harding is only useful if the power bank also support 19/20v to charge laptop. Otherwise, is simply just a fast charger. Not worth to spent the extra money.
GoodBetterBest
One question about weight.
Baseus is half the weight of the Xiaomi PB for the same rated capacity. Any idea why that is so ?
I would think the significant portion of the weight goes to the storage material which should be the same. And the rest of the circuitry should be just not so significant.
Thanks.
007Mi6
Thanks.
The first thing is, half the weight is this information even accurate?
10000mah powerbank typically 200grams plus minus 20grams.
GoodBetterBest
