FinalNitro
- Sep 29, 2011
Coming from iPhone 11 Pro Max.
12 pro max Battery life so far so good. Similar usage as how I always use my 11 PM. Phone calls, WhatsApp, wechat, social media browsing, occasional photo taking, web browsing etc. This 12 PM seems to be able to last as long as my 1 year old 11 PM. FYI my 11 PM is at 89% battery health.
Probably it’s because I turn on the “5G on” function because I’m trying to test out the 5G hence it’s draining the battery a little. Another point to note is while I was using my 11 PM it’s always on dual sim, 2 phone lines active at the same time whereas my 12 PM only switch on 1 phone line as the “5G on” function doesn’t work with 2 active phone lines apparently
If you’re very concerned about the battery then I can say it shouldn’t be a problem for you to last through the day. The weight difference of 12 PM and 11 PM can be felt too, 12 PM definitely feels lighter. Screen size wise it’s still as accessible as 11 PM, not much of a difference for me.
How do it feel on-hand with daily usage? The rounded edges vs squared-off edges
