iPhone 12 Series
tohchr
Hi, anyone here using iphone 12 series having notification sounds with the Grab app on his iphone? My iphone 12 mini does not have any sound whenever there are pop up notifications and messages for my grabfood deliveries to me. Banners, Sounds, Badges are turned on in the Settings. My other apps have notification sounds and my iphone is not on Silent mode. Any help? Thanks in advance.
Did u check the app itself? There’s also notification settings within the app itself. Make sure your side mute button is not accidentally toggle to vibrate.
ellei_ram
Thank you for your response. I could not find the Sounds within the settings in the app itself, but i toggled on Push for all the Communication settings in the app. Side mute button is not toggled to vibrate.
ellei_ram
If it's just the grab app, try reinstalling?
Thank you for your response. I already tried to reinstall. What is the notification sound like for the Grab app? Is it the same as the sms/imessage tone that I set or is it like a ping which i hear from whatsapp notification?
argentinafa
Yeap I am.
The 1% is cross border fee?
Oh good idea! Thanks.
translate from which currency?
Oh didnt know theres such a thing. The cross border fee is 1%?
Cant remember if theres such a thing when I purchase apps on Google Play Store.
Idk whatever fee is that. I just understand my calculation of + 1% is accurate, when I purchase my clash of clans in-game gems.
And you are right. When we are buying Google Play Store app or in-game purchases, it’s flat fee. $148.98 is 148.98. Not $150.47.
davi502
It should be the default iOS app notification. SMS/iMessage you can select custom alert tones. For WhatsApp you are able to choose from other system default.
I'm not a grab rider, so I'm using the normal grab app, but I'm unable to find any settings to change the notification tone.
Im on 14.2 but not using the iPhone 12 series.
grynove
anyone having the yellow display issue here? if i bought it locally can i just return it to nearby apple store?
to answer the question. its not yet 14 days
kashix
huihong
Moi XS served me well for so long le, time to make way for this dua leng gong.
JayBeeLwashere
This Color tint issue appears on oled screens, when I’m using Huawei a lot users from 1st batch complained about it too
grynove
so is it hardware issue or software issue?
after reading the news. i see myself its indeed yellowish. but myself still using iphone8 plus now. really can tell the difference
i.Singaporean
It's how the 12 series panel are suppose to look like apparently
https://forums.macrumors.com/threads/yellow-screen-tint-display-seem-warm-check-here-first.2262691/
Over 2k replies :s13:
I went to Apple Changi Airport and Orchard and compared to at least 10 different 12 Pros and they all have this yellow tint so yeah
Ahkunkun
I went to compare at Challenger and Courts too, all also yellowish.. and all the display set at full brightness is dimmer than my 12PM too (Auto brightness off on all devices)
If compared to my iPad Pro 2020, the yellowish is like super jialat...
Shadow79
Actually a properly calibrated screen is slightly on the warm side, not the cool white screen that you will find on entry level phones. My guess is Apple is calibrating to D65 standard. Even on Samsung flagship phones, if you set the screen to the natural setting instead of Vivid, you will notice it’s also warm side.
Parka
But we don't see people complaining about an Apple calibrated iMac/Macbook screen being yellow
Shadow79
This I’m not sure but the 2017 MacBook Pro I’m using the color was off out of the box. I have to re-calibrated the screen using my colorimeter.
