Biogentic
- Jan 1, 2000
Markus T would be my next go to frame. Thin, sleek, light, durable, cheaper than horn. Can even look professional with it.
What is the price range like
Hi Gangsterkia, may I know which shop in Singapore carries Markus T? In general and at least that is for me, their designs look like Lindberg. Thanks.
I know for certain eyewear optics does, you might want to call Jamco to see if they have. Likely they do too.
You are not wrong on the design similarities, both are minimalist style.
Thanks for your prompt reply. Jamco? Will ping them soon. Lindberg is from Denmark and Markus T is from Germany. Apart from Lindberg Horn series, the entire price for a pair of progressive lens using Hoya + Markus frame would be similar to Lindberg frame? Just my guessing. Thanks.
PS: just called, they currently do not carry Markus T. Haa. Save money?
Yeah, I think it might be the frame distance.There could be a few possibilities.
1)Frame position on your face differs from both frame, old one sitting closer/further and new one vice versa.
2)lens coating quality affecting clarity
The owndays is almost double the distance I think?
have a dilemma hope the pros here can help me with.
need to make lenses- both eyes around 400-500 nearsighted, astigmatism about 200.
right now choice is between foptics and "branded lenses"
foptics
1.67 - 1.74 - $70-$140
"branded" eg hoya, essilor (cant remember model range)
1.67 - 1.74 - $220 to $380
Qn is, given that the max I want to spend is up to 300-400, is it worth it to pay more for branded lenses v generic foptics lenses? in terms of clarity..vision.. can it be said branded lenses are at least 50% better?
if do branded lenses, any recommendations where to do with as little markup as possible?
Thank you everyone
Is it possible for you to go back to ask them to adjust the frame closer to you?
At least you can try to rectify it or else it be a wasted pair.
I have tried, but they told me they only do power adjustments. I'll just keep it as a spare pair and a lesson learnt.
It's not that bad for sitting in front of the computer and looking mostly straight, just bad if I'm walking around.
Depending on the clarity tolerance of different users. Some like myself, can take any kind of lenses though we can tell the difference but it won’t affect us much.
Others die die just can’t adapt to poorer clarity/quality lenses thus have to use lenses that are better.
Do take note price difference also includes quality/durability of the lens multicoat which means, scratch resistance etc...
I would go with the more branded lenses in this case based on your power but probably 1.6/1.67 rather than 1.74 which is overkill. 1.6 might actually be enough too depending on what frame you choose. Is the frame broad? At least 56/57/58 lens size? E.g. 57/17 57 lens size 17 bridge size.
Thanks for your response! I have been using cheap lenses all my life so I don't even know what I'm missing, haha.
So between paying 80 dollars and 3++, better to just suck it up and pay for branded lenses? Any recommendations on which place does it at a reasonable price? Instead of essilor/hoya those kinda branded lenses, would a good compromise be Zoff's seiko plastic lenses at 118 for 1.67/156 for 1.74?
Also, my frame is 54-18 and astig about -2.00. any recommendations on the index I should take?
appreciate it again going to foptics tonight and would love to have all these info before I head down
Full frame, 1.6 index should be fine, seiko lenses are not too bad. Only if you prefer it thinner then 1.67. 1.74 is too overkill so don’t even have to think about it!
I won’t call Markus T another “spare frame” as it would be doing the brand a disfavour. It would be classed under a rotational frame apart from Lindberg.
If you are happy with what you currently have the it be good. If you want some changes then I would encourage you to go for it!
For Markus T, you can try Evershine Optical at Toa Payoh. Although they had little models left when I visited them last year. They were switching out to Mykita, which you can consider.
Hi Snag, thanks for the details. Looks like it is a new optical shop next to a coffeeshop? May drop this weekend if I am around this vicinity.
