StanII
- Jan 9, 2007
Nope. Not this way.
What is your understanding?
Nope. Not this way.
Right side that buttonHow to ask Siri now? Press which button?
I just restarted my phone then ok liao
I think True Tone is on.Any iPhone 12 pro max users find that their screen is yellowish?
No.. use it about 30% or 40 % will charge .. when charging always take more than 2 hours .. from 97% to 100% that 3 % can take an hours .. alright will leave optimized on then ..
Hi dreamerzz,
Has your slow charging issue solved? I am facing exactly the same problem as you mentioned.
I turn off Liao the screen becomes whiter.
Hmm for their 5G VAS i was told we’re only getting 10GB, even if you apply the Data X2/3/4 plans, those only go to the 4G data capacity pool
No. Not that gap. It’s infront upper half left side. Im reffering to the space between the screen and metal band.
No .. still the same .. even 50% need 2 hours to charge.. especially the last 10% to 100 % ..will go to apple store ..
Hi bro, i also have a slight gap on my iphone 12. Intending to head down to apple store this weekend to seek an exchange. Is it possible for you to share share some pictures of your gap?
Anyone can advise is there any shortcut to scroll back to top in safari
Yes, seems like the pro max screen is more yellowish from 12 pro and 12. I saw a couple of time liao.
