Samsung Galaxy Note 20 | Note 20 Ultra
rainydae
Hi,
You can search for battery under settings. :)
Posted from PCWX using SM-N986B
shuttlex
Anyone encounter fingerprint scanning issue after putting screen protector?
Sent from Samsung SM-N986B using GAGT
zhaoweijie
Guys do you encounter when on 5G network, and using chrome will have some freezing issues? :(
Oktechie
Glass or film?
I had issue with a tempered glass i bought off shopee. Did NOT WORK
I then googled and found breakfixnow.com
had a NOTORIOUS time finding the shop in Bugis and many "imitation shops" with the name. but finally found it.
and installed glass screen protector and it works flawlessly. Even have choice of matte and glossy. not cheap but my understanding is curved ones are not cheap.
Ghostfreak123
How much did your glass screen protector cost? And also, will the edges come off easily after it being applied onto your screen?
DaRRenLieW
Anyone got a good wireless charger to recommend? The one from samsung very expensive .
Sent from Note 20 Ultra Snapdragon™ using GAGT
davidwong
Isn’t it a free gift when you buy the phone? At least I gotten the samsung fast wireless charger with fan and samsung free buds tws when I recontract but my friend when buying at samsung store they also gotten those as freebies
micshang
Can share what is the name of the shop? I googled breakfixnow.com, this is a website for domain name registration?
DaRRenLieW
Ah no leh. We buy export sd set all doesn't have free gift. The only free gift is the plastic tpu case in the box haha
dodongdodong
I got my glass from shopee also glue type paid sgd2.75. Need to press lightly the fingerprint area during curing to eliminate gap. Fingerprint scanner works well even by feather touch.
camoguysg
Anyone using the spigen neo screen protector? Any issue with finger print recognition?
huehue
Anyone can update on the korea SD version SOT and battery usage whatsoever as I might be interested in it if the battery is not bad
ltrinityl
Those using HK set, are you guys able to boot into recovery mode (by pressing volume up and power button) when turning on the phone after the 1st November patch?
Mine dont seem to be working anymore.
Also, do you all have any issues with your wifi connectivity? I keep getting disconnected on 2.4ghz band. Need to go to settings-connections-wifi then it will connect again. There is no disconnections on the 5Ghz band. My other devices on the 2.4ghz band also does not disconnect at all.
