Huawei P40 Series
saltyprince
To which 131 fw did u downgrade???
Them did u upgrade the fw???
What is the latest update for singapore p40pro???
I just follow instruction on "hisuite proxy" app, i just got my set from m1 and out from box firmware is 15x,tried googlefier but unable to install so I downgrade to fw 131 using *hisuite proxy* app, the app will guide u to correct fw to download
saltyprince
I haven upgrade my fw yet, still on fw131, busy with installing apps, so far stable, no rush to upgrade fw
saltyprince
Some of the apps i download from huawei store, i see update available from. Google playstore for the same app, will update from google playstore crash the app?
saltyprince
Why google playstore detect app that i dl from huawei store? I understand they have same name from same developer. I am talking about m1 app. Install from huawei store but googleplaystore detect it and told me update available. Btw i turn off auto updates on both store
sars8888
Why you install gms? Play protect will scan through every one of your apps installed.
bubbasour
Contactless payments on P40 Pro
hi experts, i'm a new owner to a p40 pro which i like very much.
i wanted to have some tips if I there's any work around for contactless payment?
I understand there's a ban in place and gpay does not work, and when I check Wallet in the phone, it does not support VISA/MASTERCARD it seems, only some chinese and russian banks it seemed.
However, is there any other app that can be used for nfc payments in fair price and other common pay wave shops?
appreciate any tips. thx
tohchr
Singtel dash is one of the payment that I used.
bubbasour
thx, i install it and it seems helpful, but is there a way to link the app directly to my visa so that i don't manually have to top up specific amounts that may leave trailing amounts on the balance?
tohchr
U can set it auto top up once it hit a minimum amount. Example for me, it will auto top up once the value is $20 or lesser.
bubbasour
WiFi Calling / VoWiFi on Singtel and M1 for P40 Pro
Hi,
Can someone pls confirm whether 'Wifi Calling/ VoWiFi' (not VoLTE) profile is available for Huawei P40 Pro on their device using SingTel and M1?
sos911
P40 Pro / singtel
Yuripa
Noob question -
For users who have sideload gms, can GPay be used?
To make transport payments via nfc or shopping at supermarkets etc.
Posted from PCWX using GAGT
1982-1994
gpay cannot be used
the last Huawei phone that gpay can be used was p30 series
boaboy
Managed to do a photo comparison of huawei p40 pro with mi 10 ultra
nyf_kenny
I have sideload gms but facing some problem not sure if it only me.
Anyone have issue of Carousell notification not coming in and is there a way to save new contact on google contact instead of phone itself.
Any kind soul can point me to some direction will be great. Thanks in advance! Appreciated!
bylee123
Which is the right fw I should get?
Hi everyone, I'm being very careful here cause I just got my phone back from service center after 1st try of downgrade FW. My phone just reboot every 20 secs after that, making hisuite method not usable.
my device is ELS-N39 C636. Currently on ELS-LGRP6-OVS 10.1.0.155.
so to downgrade, I need to downgrade to which version?
anyone with success case, could point me the FW that will work?
has anyone use the OTG method before? is it more convenient that Hisuite method, since I can download the fw without needing to connect phone?
Thanks!
nyf_kenny
Thanks!
I'm managed to install GMS on 10.1.0.131
