Google Pixel Update - Android 12 July 2022
limmk
That's weird.. I didn't see it in my phone after updating..
Update sound amplifier from play store
limmk
Google rolling out the final Pixel 2 and Pixel 2 XL update
RIP old friend :(
The OTA update will roll out in phases depending on carrier and device. Users will receive a notification once it becomes available.
Get security updates & Google Play system updates
  1. Open your device’s Settings app ⚙️
  2. Tap Security 🔒
  3. Check for an update:
    ◾ To check if a Security update is available, tap Security update 📱
    ◾ To check if a Google Play system update is available, tap Google Play system update 📱
  4. Follow any steps on the screen
Eoux6CMXIAI7whw
Factory Images for Nexus and Pixel Devices
Full OTA Images for Nexus and Pixel Devices
Android Security Bulletin—December 2020
Pixel Update Bulletin—December 2020
limmk
Tried but still not showing in my phone. Not sure what's going on.
Note its only for the p4a5g and p5. my next step is to clear cache for sound amplifier/google play services
Especially the way google works ... sibeh pek chek
google play system update; one shows oct; the other dec
bryant_16
Sorry, my bad.. didn't realize is for those devices. I'm on a P4XL, no wonder I couldn't get it running.
Anyway, noticed that apps start running at a faster speed than previous build, not sure if its placebo effect.
limmk
Ya 'exclusive' features or 'encourage' you to buy/replace phone 😅
Think helps run smoother also 👍🏼
