FYI/A: Bufferbloat 101
hwzlite
Latest Update On 04/2024 :
The go-to-de-facto Web-based Tests now is https://www.waveform.com/tools/bufferbloat
As it was reported that https://www.dslreports.com/speedtest somehow time to time broken in one way or another...
Good video info here for people who are new to bufferbloat ( thx to bro @xiaofan for the head-out :cool: ) :
A picture speaks a thousand words:
XXXXXXXXXXXXXXXXXXXXX Original old reference info below Last edited on Dec 18, 2000 XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Here was my test result (M1 500mbps fiber cheapo plan) , tamed under DD-WRT (D-Link DIR-868L) router.
HSFC+CAKE SQM :
http://www.dslreports.com/speedtest/66614028 -
Optimized pure CAKE mode which by design works best without any rate limiters sure as HTB/HFSC scheduler.
(For some strange reason, the developer of DD-WRT did not make a standalone Option for CAKE , so have to tweak it via CLI ) .
http://www.dslreports.com/speedtest/66656741 -
FYI: Consolidated SG ISPs speed test results:
Examples: Results from those untamed top-tier 1GB plan, upload bufferload (lag) under load can reach as high ~900ms :s22: :
M1 http://www.dslreports.com/speedtest/66518951
Singtel http://www.dslreports.com/speedtest/66598644
Starhub http://www.dslreports.com/speedtest/66471859
:s12: http://www.dslreports.com/speedtest :s12:
uncle_josh
Explaining And Fixing Bufferbloat
Bufferbloat is high latency (or lag) that occurs when there’s other traffic on your network.
What’s wrong with simply configuring QoS?
Quality of Service (QoS) settings will help, but won’t solve bufferbloat completely. Why not? Any prioritization scheme works by pushing certain packets to the head of the queue, so they’re transmitted first. Packets farther back in the queue still must be sent eventually. New traffic that hasn’t been prioritized gets added to the end of the queue, and waits behind those previously queued packets. QoS settings don’t have any way to inform the big senders that they’re sending too fast/too much, so packets from those flows simply accumulate, increasing delay for all.
Why does SQM work so well ?
These smart queue management (SQM) algorithms put each flow’s traffic into its own queue. (A “flow” is typically defined as traffic from a single IP addresses/port to another address/port.) Then the qdisc makes sure that none of the queues get “too long”
For more information : More about Bufferbloat
Of the big three, M1 > Starhub > SingTel. This is probably due to the fact that default M1 router is better and default SingTel router is lousy (especially AC Plus and AC Elite which were given in the past few years). M1 latency is also usually better than SingTel. Starhub is usually in between SingTel and M1.
I tend to believe many users use WiFi client (lower bandwidth) to test. If using wired client, probably the issue will be less severe as majority of the local users are on 500Mbps or faster connections.
But if using wifi, users using poor wifi routers/AP like the SingTel AC Plus will often have low speed connection and then bufferbloat issues may present more obviously.
miloaisdino
singtels bufferbloat is quite bad imo. when the line is saturated the ping can spike to few hundred ms. will publish the results later. and during certain times of the day, testing is inaccurate since the dslreports server is softlayer sg, which singtel has poor routes to.
-Grift-
Quite sure your router plays a bigger part
Tested with my Huawei P20 mobile phone on WiFi, SingTel 1Gbps Fibre, Asus RT-AX82U router
http://www.dslreports.com/speedtest/66622024
I think I selected wrongly "Public WiFi" for the test.
Now I test again by the correct "Fibre" selection and the result is bad.
Mac Mini M1 on WiFi (2*2 AX), Chrome browser, Singtel 1Gbps Fibre, Asus RT-AX82U.
Bufferbloat is "D" or "C" even though Quality is A+.
http://www.dslreports.com/speedtest/66626339
http://www.dslreports.com/speedtest/66626339.png
maybe thats why :(
zte from china sucks.
Interesting. So you think the ONT plays a part. I am also using the ZTE ONT. I replaced my old Ericsson ONT back in Sept 2018 because of bad power contact (using it from the beginning of my sign up in Feb 2012).
Mach3.2
Wired ethernet connection to switch, then to my pfsense router.
Custom settings, 32 streams up and down. I checked the logs and only 8 streams are downloading for the download test though.. :s13:
