Taro Pie
- Apr 2, 2015
Just curious, EEC eye assessment cost over $200. If not suitable then how ah?
Go shinagawa do assessment
$22
Posted from PCWX using 成何体统
$22
Just booked an appointment at Natasha Lim clinic on upcoming Tues. If suitable can do on the spot for iDesign iLasik.
Anyone here done this before or have visited her clinic?
Hi shinjiono84, did u manage to get your eyes done on the spot at Natasha Lim’s clinic? How was it? Care to share your experience?
Nope my cornea too thin, so it's either icl or transprk
$22
Posted from PCWX using æˆä½•体统
Felt like my eyes have fully recovered as I am not seeing any haze nor experiencing any dryness in my eyes anymore.Why not spore national eye centre?Hey bros! I just did Bladeless Lasik at EEC a 4 days back and it was really painless but scary at the same timeFelt like my eyes have fully recovered as I am not seeing any haze nor experiencing any dryness in my eyes anymore.
However, I saw from a few previous posts (this thread) and a friend who did Lasik in EEC before that that their vision was not corrected well after the Lasik surgery. Heard that the staffs and doctors will "smoke" you saying that it will get better until you finish your last consultation with them. I am currently facing the same issue as my right eye is not as clear as my left eye when looking afar but was told by the staffs that this is normal as it is still healing. Would like to check with any bros if I am also being "smoked" or it is actually normal that lasik do not fully correct your vision like mine and the others?
P.S I still picked EEC as my go to clinic as I had referral discount from an acquaintance but found out that they do not actually have a discount thereafter![]()
I did the lasik @ EEC too, 5 months since my opHey bros! I just did Bladeless Lasik at EEC a 4 days back and it was really painless but scary at the same timeFelt like my eyes have fully recovered as I am not seeing any haze nor experiencing any dryness in my eyes anymore.
I only can say that 1st 3 months will be filled with ups and downs. There are days you will be wow by the clear vision and there will be days you will be panicking as the vision blur badly.
Give it time. I took about 3-4 mths to stabilise. During the first 3 months I made alot of last minute "emergency" appointments as I got panicked due to the blur vision suddenly.
Reasons back then were:
- Dry eyes
- side effects of the steroid drops
- allergic to steroid drop that caused the eye pressure to increase TREMENDOUSLY
So although i can say give it time, but don't brush it aside if you feel its not right. Only you yourself knows.
actually the stinging feeling is normal. its supposed to have that.I am wondering how would someone know if they are allergic to the eyedrops?
I was originally having no stinging feeling when using the Tobradex steroid drops given to me but suddenly for the past few days, whenever i drip them into my eyes, at that exact moment, it stings, but the next second or two later the stinging is gone. Should I be concerned?
Lasik cannot cure astigmatism right?
It can correct astigmatism
