[Recommend] Good Mechanical Keyboard
nez
I didnt know too till i saw the bfcm offer lol. Was about to buy from official keychron, then fiddle around saw this local shop listed in where to buy section.
Thanks for the heads-up
rECKleSSfElla
Not sure why its not listed in the title but in the Switch Type selection it did indicate "Gateron (Hot-swappable)"
The writeup also indicate
K4 version 2 has full-size functionality in a compact design with 100 necessary keys. The hot-swappable option with preinstalled Gateron Mechanical switches offers the freedom to customize per-key typing experience without soldering.
May write to them to clarify.
Anyway anyone wants to order? I want to save on shipping.
Mecha store free local shipping using qxpress as courier. Receive within 2-3 working days once they ship out. They also have store front at Amoy street which you can go to for self collection but best to check with them for availability of stock before ordering.
If you order direct from keychron website the shipping is about USD$13 and if i am not wrong they charge it per quantity ordered so even if you consolidate multiple orders they will still charge USD$13 per piece.
nez
I see. Then better get from mecha.
xonix
Have a question for those who have modded their keyboards before...
If you remove the battery from keyboards with dual connection mode ( BT & USB-C ) will the USB-C connection still work ?
kingsen
Have you guys tried Razer Huntsman Elite?
Using the huntsman elite tournament edition now. Solid build.
- detachable Type-C cable on left side
- TKL
- doubleshot PBT keycaps with normal fonts
- standard layout
- sleek and simple design
- linear optical switch
Only thing is it is super sensitive. Need some time to get used to the 1mm actuation. Standard layout also means anytime can change keycaps.
nez
Planning to get a wireless mechanical keyboard, worth it to get? or can anyone recommend one
Currently using back a Logitech K270 (previously bough for office use) wireless as I am cleaning out my mech keyboard. The no wires look is really nice & clean not to mention super convenient.
Currently playing cyberpunk 2077 with it :D
But of course the typing experience no match for mech board
Mr BBFA
looking at tecware keyboards, the prices looks attractive :eek:
which switch would you guys recommend for gaming?
kalih speed silver?
Mr BBFA
ehhh they're kinda average stock though, not sure if everyone wants to spend the time and effort to lube and film them...
hmm got other kbs and types of switches to recommend for gaming?
Preferably not too soft to press, must have some resistance.
in white if possible to match my speakers and pc :s13:
max budget around 130ish?
how are speed switches? are they easily activated if accidentally touched?
Yongkit
Razer BlackWidow Mechanical with Orange switch is very good & slient if you are alright with Razer.
you can try it at challenger but check the price at amazon and you will be surprise for the price differences :)
xDragon
I don't really like the notion of 'switch X is better for gaming than switch Y' because it's really subjective. Plenty of people use clicky/tactile, heavy switches to game and they're fine. Objectively, a switch that has low travel and high actuation point would be better for gaming but honestly I think people should just go for the switch that they like the most in terms of feel.
I use my buckling springs most of the time unless I'm doing stuff with a lot of double presses due to the heavy springs and travel distance...
White wise just pick any case/keyboard that's white and pair with white keycaps lol nobody gonna see the switch housing/stem color unless you're getting a low profile case, idk why so many people have a hard on for hipster colored switches
Regarding 'speed' switches you'll probably just have to use them for a while. You'll get used to the higher actuation points/lower travel in due time
Mr BBFA
i've heard a lot of bad things about razor quality but i'll take a look! No issues with amazon bought one, my current bought from amazon US at least 5 years already still going strong :s13:
Hmm so far i've tried mx blue which i dont really like, halfway pressing there's a click which i believe is the actuation point which the keystroke is registered before it bottoms out?
I'm currently using cherry mx reds with o rings which i prefer, no click when the keystroke is registered. I believe it is linear switch? The o rings which i use shortens the distance before a keystroke is registered and bottoms out am i right?
I'm considering speed switches, but my main concern is the force needed to press a key being very light. Like with very little force and the key is pressed. I'd prefer keys where i can lightly rest my fingers on top of them without being activated or pressed down. Right now the cherry mx reds are fine, a little harder would be great.
Sorry for my lack of understanding of mechanical keyboard terms, still quite new to it.
xDragon
You can try to look at Gateron Yellows, retooled Cherry MX blacks or Gateron Ink Blacks if you want linears I guess. An alternative to your current setup would be Silent MX reds.
You could also swap the individual springs out for heavier ones if you decide to get a switch that is too light for your current preferences (eg. swapping your MX red springs out for 67g-90g springs).
Mr BBFA
the ducky one 2 sf white looks good though. yeah switch wise most likely i'll prob go with a mx red switch, thought of trying out a brown one though :s22:
for those using ducky keyboard, any recommendation? i prefer the 65% layout with arrow keys.
thought of doing a black / white theme, any recommendations on pre built one? otherwise it's either a black / white board and the remaining keycaps gotta change
