Nope, only when its approved then you can proceed to purchase so dont needa worry on that
Hi bro,Yoga Slim 7, with either 4700U or 4800U. If you just want a light and thin laptop plus some light gaming.
Not true, you proceed to purchase after PSG application is approved. However, still need to submit claim after 1 month for approval before you can get back the 80% subsidy.
Depending on circumstances and/or checks by IMDA, there's a chance your claim might not be approved even after you made the purchase.
Hi bro,
which psg vendor provides the yoga 7? Looked online and i couldnt find any.
Just a quick confirmation here. Can a sole proprietor company claim under the PSG grant? Anything to look out for?
anyone knows any vendor that provides hig end laptops with a good graphics card bundled? that can be used for graphic editing and engineering software? so far the laptops seemed to be more for entry level.
Not really cheap consider that the prices are marked up for outdated specs.
Don't jump into the M1 chip blindly, not everyone enjoys using macs.
I wonder if it's possible for have one apple 2 thinkpads.
There's more than 1 vendor offering upgrade for thinkpads/ thinkbook.
Can get nvidia mx??? dGPU and i7
but
- i've only been checking out thinkpads, not familiar with other brands (maybe other brands also have something suitable for you too.
- the recent AMD models are supposed to be much "better" than the Intel ones. but AMD models are not available to us for PSG, afaik.
- the various MX dGPUs appear to be equivalent to desktop versions that are pretty weak, by 2020 standards.
- the claim process for an "upgrade" requires a few more steps.
try to talk to a vendor on the phone, if you need to understand the claim process for upgrades. a lot easier this way.
i've applied the grant on 20/11/20 but until now theres not news or update yet. maybe because going to end soon so alot ppl apply. so i suggest if anyone wants to apply maybe can apply 1st. not sure how long it takes to approve cuz the grant ends at 31/12/20.
i think for upgrade, after grant approve then discuss with your own vendor how you want to upgrade as its not involve in the grant and you have to ownself top up.
US$1,299 in the States before taxes. https://www.apple.com/shop/buy-mac/macbook-pro/13-inchI saw the M1 chip Mac book price is at $1999 compare to $1299 from Apple store. So marked up of $700 n I don’t think there is any spec or warranty difference.
So you have to pay $499+$300 + $140 (GST). So around $940 ?
S$1,849 in Singapore after taxes. https://www.apple.com/sg/shop/buy-mac/macbook-pro/13-inch
