EveMuffins
- Mar 16, 2005
I asked before. Was advised to download other launcher.Anyone can advise and teach me how to disable the Poco apps drawer?![]()
I didn't get the notification for 12.0.6. I check for updates also don't have. Mine is still 12.0.4 same as the bro above.
Hi, anyone rooted the phone?
Installed G Pay and Vance?
Got link? TIA
for global rom, no need to root to installed them.
This is weird. .06 was released quite few days already. I believe others also got it.
Dont have lah, wah piang, maybe you special.
anyway, i download the latest .zip and update myself manually.
Is there anything wrong with my setting coz i didn't receive the update for 12.0.6?
tks..will do it manually..i also didnt received any notification abt the update too.
you can juz install the .zip file into your phone manually
Get a phone finger ring for better grip, anyhow hold also won't drop.Recently changed my phone to Poco X3. Love the NFC function which my previous phone don't have. Currently using this nillkin hard case. I think is not bad but a bit slippery to the grip.
Want to check what are your battery drain rates like? I feel that sometimes it tends to drain a bit faster. Maybe cos background processing. But the standby is amazing sometimes not even 1% overnight.
