VIVIFI
Rxgn
Okay, thanks for the info.
My lines on M1 and they have three fixed billing cycles - 7th, 14th and 21st of the month.
So Vivifi is one fix cycle from the start to end of every month?
yes for me. Maybe need more ppl to report their dates too to double confirm
Sent from Samsung SM-A705MN using GAGT
CPTMiller
你猜你猜你猜猜猜;131774257 said:
For Dec bills, due date is 28 Dec. As payment is automatically through the credit card that you provided.
Consider good giving 28 days usage first then for payment deduction on 28th each month
*adiBOY
Can I check if anybody knows what are the billing cycles for Vivifi?
Start, middle or end of the month?
The invoice date is always first day of the month. Due date is by 28th of the month.
blue00
is vivifi network good?
using my every 2 weeks at midnight no signal when i work ;(
dredd
I am considering porting over from giga
Is call forwarding supported?
I just found out call forwarding doesn't work on giga... :(
Sent from Asus ASUS_I001DE using GAGT
dexboi
Yes, call forwarding supported on Vivifi. I have forwarded my Vivifi line to my other main line.
dexboi
I can second Vivifi's signal is better than M1. Most of the time my M1 signal is 1 bar less than Vivifi.
Give Vivifi a try, they are really fuss-free no frills MVNO. :s12:
rainbow99
recent user of vivifi via porting. can i check if my previous telco line will be auto terminated/prorated with the porting? thanks.
ZrE0_Cha0s
once u port over, its consider terminated of the contract you have with the previous telcom. as for prorated, u will need to check with your previous telcom, but i think most do, a few does not (esp like GOMO)
rainbow99
thanks bro for sharing
CPTMiller
Vivifi uses Singtel network should be better
dredd
Saw this...
VIVIFI Plus (6GB) is now available at a promo price of $9.98*/month.
*$9.98/month for the first 12 months; $12.98/month thereafter.
So need to port out again after 12th month?
Anyway...i just signed up and submitted the port in
Now need to find time to self collect....
mosmos
High Honorary Member
Ya i just collected my SIM card, according to sms porting will process tonight, hope no OTP problems as some mentioned
dredd
Mine failed on Monday night
Resubmitted again yesterday and it was successful
hfngshnll
i am on the lite plan for 4 months now. ported from singtel combo2 to singtel 12 months sim only to vivifi lite. so far so good. all my critical essential otp sms worked right from day 1. good luck and cheers.
RLWZ21
Hi, can check with you is the collection from them quite seamless? And is there anything to take note as well?
As my mum will be collecting on her own due to the name of the number is under hers.
mosmos
yes, just 1-2mins settled.
Just need to tell the person in vivifi uniform your order number and show nric. No need signature.
You can collect on her behalf, just fill in the authorisation form in the confirmation email.
