DBS changed its Mutiplier plan
lzjlee
Looking at transferring spare fund to SAYE. But if there is a month there is no salary crediting what will happen ah? Is it no bonus interest for that month only or game over? Anybody know?
In case change job and there is a gap in between for salary crediting.
Squaredot
There are some risks to SAYE. For instance, you can't withdraw in 2 years and must credit your salary every month.
BTW, you may also choose posb cashback+SAYE.
+1
and POSB bonus 2% is subjected to change? Think it's written in T&CS...I'm not sure :o
Squaredot
Why need to spend $6,667 on CC and $1,000 on RSP? You just need to spend $0.01 on CC and $100 on RSP to unlock these two category.
Assume someone has $6,667 salary, $0.01 CC spending and $100 RSP, POSB Cashback Bonus will give $22.5 cashback per month ($20 from salary, $3 from ETF RSP minus $0.5 charge). This is equivalent to 0.54% p.a. interest rate for 50k (or 0.27% p.a. for 100k). And he's free to top-up the 50k (or 100k) to Singlife, ELASTIQ or other products to get another 1.0%~1.8% p.a. interests. So total interest rate is 1.54%~2.24% p.a for 50k (or 1.27%~2.07% p.a. for 100k). If the interest rate from Multiplier is lower than this, it's worth to convert.
good thinking, thanks :love:
Ca5per
Again. I know ask alot of times liao.
What are the better choice for rsp?
Sent from Samsung SM-N960F using GAGT
maumu
What if someone lose his/her job?
seems like you'll have to restart from month 0... reapply again. yes this is probably the only risk to consider.
+1
which product don't have terms subject to changes? it's all about grabbing the fruits before they turn sour... with rates everywhere so low, I don't think there's any point waiting. if rates drop and it's no longer worth it, move on.
oceanicmanta
it's not correct that 50k gets 2.24%pa or 2.34%pa ... it's not additive, think there's a mistake.
The best for 50k is 1.8%pa in Elastiq, so might as well put all 50k there ... if blended with DBSM, the EIR will be lower than 1.8%.
For 100k, 50k @0.54% + 50k @1.8% gives 1.17%pa .. again the best for 100k is 1.8%pa in Elastiq, dont see how to get 2.07%pa
The above EIR is just slightly better if 10K is allocated to SingLife @2%. In excess of 10k, the 1% would lower the EIR.
Squaredot
Of course u can move if bonus rate falls, u just don't get your bonus interest lor. So what's the point of "committing" to SAYE 24months??
I will not continue discussion on SAYE :s13:
TsukiSG
The calculation is blending of POSB Cashback Bonus with ELASTIQ. It is additive since you do not need to keep balance in DBS.
oceanicmanta
Yes, you are right !
The % return from POSB ** is cash back, not interest earned on balances.
My apologies. :o
vsvs24
I won't want to be locked down for 2 yrs. Betting that rates will be better next year when digital banks start.
tytyty333
Simply invest $1000/m to bond RSP for 3-0.5=2.5% rebate. Sounds very nice.
The risk of a bond is relatively lower than STI or Reits.
reddevil0728
Oh, so good etfs also eligible for the posb cashback right?
Valid for POSB Invest-Saver, Unit Trust Lump Sum Investments, and Unit Trust Regular Savings Plan purchased after joining POSB Cashback Bonus
"POSB Invest-Saver"
Ca5per
"POSB Invest-Saver"
So only rsp is valid for posb cashback?
I am so confused . Haha
reddevil0728
did you visit the website to see what's under the investment category? if you didn't i suggest you go take a look. a lot of useful information there.
Ca5per
Yes i did, but i don't understand.
Is etf = rsp? Lol
