XIAOMI MI 11
cscs3
Is best to wait a while just like Mi 10 case. Follow on model on same series should be much cheaper.
lch920619x
Have device on hand. It's not good, I would not recommend it to anyone. Snapdragon 888 is a total failure
Tsoukalos
How issit worse when it's suppose be faster chip? Can educate us?
Sent from 西方极乐世界 using GAGT
eyz
I think it's better that you go watch the video.
it's very technical, they analyse every single component on the chip.
quite a few of the components on the SD888 are simply overclocked from SD865, in order to achieve the faster speed, but that in turns increase battery consumption and higher heat output.
lch920619x
888 is not power efficient, performance is top notch but it generates too much heat. device is noticeably hotter compared to 865 and Kirin devices
However I love the form factor and display. It's comfortable to hold and enjoyable to look at. So wasted
Just Me
Battery is less than 5000mah what you expect? 50 mins for a full charge using 55w gan. Nowadays battery charging is so fast that it's not much of an issue
Sent from Xiaomi MI 9T PRO using GAGT
Lil_d3viLz
I doubt you having that device.
