I just ordered China Tuf-ax3000. Intending to use aimesh with ac88u and ax3000 as a aimesh node. Would there be any problem?
Anyone upgraded to the new firmware? Assassin mode working?
Should be okay. You may need to set the region to Asia to have the same wireless bands in order for the AImesh to work.
That's bad, since my main router RT-AC88U was from Amazon US. I checked the regions and it is US/06. Will aimesh have problem with AX3000?
Maybe my area not as good as u have, with that 26dbm, further place i can use is only outside my 4 rm flat corridor.![]()
Asus TUF-AX3000 Assassin mode limitation:
1) Only avaible as the main router. It will not be available as a AIMesh node, as per CoolShare forum post.
2) The wireless performance will be similar to RT-AX82U (4T4R in 5GHz, 2T2R in 2.4GHz), but there will be no link aggregation feature as the RT-AX82U, no LED effect. But the difference is not that important.
Hi xiaofan,
Newbie here. I have a similar user case here. I ordered China Tuf-ax3000 to use aimesh with my local set ac86u (zaku) and to make ax3000 as a aimesh node. All I need to do is to change the region of ax3000 same as ac86u (Asia?) before set up aimesh, right?
Thanks!!
Thanks for your prompt reply. Just to share my current set up on AX86U + China Tuf-AX3000 (managed to make the mesh work this afternoon)Sorry but I do not know.
I was thinking it should work but there seemed to be negative reports in this forum.
The Tuf-AX3000 arrived this morning (Purchased from JD). After unwrapping the box, I didn't make any setting direct on it but instead, used Asus App to connect it as a AImesh node to AX86U (router mode connect to Singtel ONT), it took about 4-5 minutes to complete the auto setup and now I can enjoy full wifi coverage and boost speed in master bedroom (3 walls away from the main router, not even able to watch youtube in HD mode previously).
I found there is no way to check/change the setting on AX3000 from Asus App since it is in node mode. And I guess the regional setting should be auto-copy from the main router (Default Asia)?
Thanks for the guidance. Tried to put the IP of AX3000 into browser to launch but always force navigating back to AX86U web UI.Thanks for the updates.
You can use the web UI to check the region setting of the TUF-AX3000 mesh node. From the main AX86U router, check the IP address of the mesh node TUF-AX3000. Then launch the browser and point to the IP address of the TUF-AX3000.
In AI mesh mode the secondary node will always forward u to primary node web UI for Login.Thanks for the guidance. Tried to put the IP of AX3000 into browser to launch but always force navigating back to AX86U web UI.
Only when u click USB application it would than being up the login screen for your secondary node.
What sort of settings are you looking for ?I managed to see AX3000 UI through USB application from your tips. But it seems there are very limited options for me to check the setting of the node AX-3000.
