Redmi 9 series
kazuki666
Anyone saw the 128gb 9T on shopee? Strange it seems to be not selling?
Sent from Xiaomi POCOPHONE F1 using GAGT
rainbow99
can check if redmi 9t can use the redmi 9 screen protector? seems very hard to find for 9t
RLWZ21
Please don't buy redmi 9 SP. Redmi 9 and 9T is different screen size. U can consider buying Poco M3 as they are of the same build.
rainbow99
The redmi 9t sets here have no NFC, is it a hardware or software limitation? Quite a bummer not to have
Sent from Samsung SM-G9860 using GAGT
ZrE0_Cha0s
company limitation :(
only a few country they give have this features while many others does not
rainbow99
Thanks bro. Does it mean can flash another country ROM to get NFC in the local sets?
kazuki666
It's software limitations, not hardware???
Btw, anyone using the local set 128gb? Can give some feedback?
ZrE0_Cha0s
well i dun meant it that way, but im think it might be xiaomi manufactured the phone with model that is build with nfc hardware and software, while another is build without it.
rainbow99
Oic, if hardware then kinda short end of the deal for the buyers here. Thanks for sharing bro
kazuki666
So if I buy a local set which claim don't have NFC, there is no way they can put the function back with firmware updates right?
kazuki666
What if I buy an foreign set which claims to have NFC???
BluEsiGn
redmi 9
Hi,
if im looking for redmi9 at taobao, does 全网通 means global version?
or all xiaomi from taobao is export version only
ZrE0_Cha0s
nfc is hardware de....even if got firmware also no point.
ZrE0_Cha0s
Hi,
direct translate : The full Netcom mobile phone refers to the mobile phone supporting the six mobile communication standards of China Telecom, China Mobile, and China Unicom, including TD-LTE, FDD-LTE, TD-SCDMA, CDMA (EVDO, 2000), WCDMA, GSM (GPRS) ) Six-mode single and dual-card mobile terminal. The five-mode terminal products that do not support CDMA (EVDO) can meet the needs of more than 70% of domestic users and are considered to be "quasi-full Netcom mobile phones."
It does not meant global version. beside that getting from taobao mostly china rom...and yes they are all export set.
BluEsiGn
i'm looking at official xiaomi in shopee, it says the global version phones are all ship from china, so im wondering if i want to direct buy from taobao, what should i look for to get the global version instead of china rom. want to get those with direct google play instead of installing myself but not sure can find from taobao or not.
