The Watch Thread - Part 16
Edhomme
Hi watch gurus
Interested to get an IWC. Anyone knows how much discount is offered for IWC by the retailers here?
shinoku2
This has become my daily beater
fade_white
Does anyone know where I can buy or custom make straps for deployment buckles? (i.e. without the hole for the buckle tongue)
thanks in advance
cyrenic
thanks in advance
Just search for straps w deployant clasp instead and replace with yours.
If not the usual places with custom make will do it for you I'm sure, delugs for example.
fade_white
Thanks.. That did cross my mind but I’m thinking order those deployment straps + clasp will have that leftover redundant clasp that I’m paying extra for.
Know of any local leather craftsman that do straps?
Thanks.
ceestudent
Thanks.
It depend what leather material and budget you want. Usually i just buy the normal one with buckle and replace it with my own deployant clasp, just need to make sure it have same buckle width.
Can take look at nomad if you need to go physical shop. If want more premium, go fir delugs.
jonleelk
Straps for deployant clasp, the short length need to be shorter than those for buckle. Else the deployant clasp will end up in a very uncomfortable position under your wrist.
I customise my deployant starp from Delugs under their MTO range.
