VIVIFI
mosmos
High Honorary Member
Mine failed on Monday night
Resubmitted again yesterday and it was successful
Sent from Asus ASUS_I001DE using GAGT
Mine porting also failed on the first day, not sure why. :s22:
2nd day porting is successful. Porting from MyRepublic. MyRepublic line was cutoff at 11pm+ yesterday but the porting over was not done yet till 2am. This morning wakeup at 6am then completed
(Updated 30 Jan)OTP with ocbc, cimb, singlife, shopback, singpass, capitastar, Maybank, SCB are ok.
dredd
OTP with ocbc, cimb, singlife, shopback are ok.
Weird right?
I was very sian when the port over failed
2nd night i received email from giga my line has been terminated...fingers crossed..it worked when i woke up
mosmos
Weird right?
2nd day porting time too so long, i still thought that my old number will be lost forever. I called my own number at 2am and the announcement was this number was not available :s22:
Last time porting from M1 to redone and redone to myrepublic, total process only took about 5 mins :s22:
mosmos
About 30kB/s, just good enough for texting apps and safe entry.
Yes, just now go redeem pancake on shopback go app and do safe entry at ntuc, i can also surf hwz forums and FB using opera browser
IG app is very slow
guyz92
Throttle speed it seems like Zero1 is still leading with 1Mbps.
My 6u plan with Zero1 after using more than 10GB, it still throttle around 1Mbps. Previously on 1GB to Unlimited after using 5GB it throttle to 512kbps.
So far no mvno provide unlimited 3mbps to 8mbps plan. Overseas mvno they have such service.
Maybe Zero1 can survive due to unlimited 1mbps plan meets the usage pattern of foreign workers living in dormitory. Maybe not all dormitory provide WiFi service where the unlimited 1mbps meet their needs.
crystalnox
They watching their drama, 1mbps where got enough.
lohsenglte
Probably 480p streaming is good enough for them.
May even stretch 720p if the video encoding is efficient, based on the experience on TPG XL Unlimited (the long gone free service trial).
lohsenglte
IG app is very slow
Instagram needs way more bandwidth than 256kbps. IG Stories easily consume 3-5Mbps for decent quality video stories. If 1Mbps, it'll both be on potato quality and buffer every couple of seconds. IG Stories (pictures) is fine on 1Mbps.
reivaxx
Good download speeds
On the VIVIFI PLUS plan and having 180Mbps down and 20.5Mbps up at 9pm at Choa Chu Kang, seems pretty good for a MiFi SIM card! :) (Tested with Speedtest.net)
Yihaoong
vivifi share plan look so outdated. Either upsize the data or lower the cost.
FinalTidus
Going to collect my VIVIFI sim card today. Got the VIVIFI lite plan.
Hopefully everything goes well!
kurt111494
Hi guys,
If using Singtel Corporate Plan previously, possible to port in right? I hope the process isn't too troublesome...
Also, there are no Corporate discounts for VIVIFI right?
dexboi
Anyone know if Vivifi supports IPv6? I need it to set up VPN. Can test here:
https://test-ipv6.com/
Your IPv4 address on the public Internet appears to be 111.65.XXX.XXXX
Your Internet Service Provider (ISP) appears to be SINGTELMOBILE-AS-AP SINGTEL MOBILE INTERNET SERVICE PROVIDER Singapore
No IPv6 address detected [more info]
You appear to be able to browse the IPv4 Internet only. You will not be able to reach IPv6-only sites.
To ensure the best Internet performance and connectivity, ask your ISP about native IPv6. [more info]
We are sometimes unable to detect Teredo and 6to4 when using HTTPS. [more info]
HTTPS support on this web site is in beta. [more info]
Your DNS server (possibly run by your ISP) appears to have IPv6 Internet access.
Your readiness score
0/10 for your IPv6 stability and readiness, when publishers are forced to go IPv6 only
