- Sep 16, 2018
Basically at 1Gbps, the benefits of QoS and SQM become questionable and you need very powerful router to handle this. UDM Pro can only handle 800Mbpd SQM as per the article.
Yes, understand SQM is quite cpu intensive. However I have seen bufferbloat cause the entire home network to lag. So this is a must have feature for my consideration for my next router.
So in the end, to me SQM is only nice to have. If you have a powerful router which can run SQM at fast rate, by all means enable the feature. But for most of the people, just live with whatever the bufferbloat scores you can achieve.
The goal of the bufferbloat project was to “hold latencies low or constant, no matter how much bandwidth you have.”
The impact of bufferbloat can be profound and subtle.
Profound: Especially on those asymmetrical xDSL/Cable with low line speed.
Once line speed saturated, all hell breaks loose on latencies.
Subtle: On Gbps fiber, spike/jitter latencies ensured once line speed saturated.
Only obsessive gamer or netG33k will make every ms/rtt counts on taming latency-sensitive applications
fyi: My Past rants during my days on cable
with openwrt SQM.
off-peak
The thing is that you seldom saturate the line speed on 1Gbps Fibre, other than speedtest or connecting to some local download servers. Gaming will certainly not saturate the gigabit Fibre connection, or even 500Mbps connection.
My point is that the ISP routing and wireless connection are contributing more to latency. So for gamers, use wired connection, and choose better ISPs like Myrepublic and M1. And use a relatively good router. After that then you need to worry about bufferbloat.
Wah, so long never visit VRzone until I click on your link...now like semi-dead forum......![]()
Yes if you assuming single user
But.... Typical scenario - 500Mps connection shared with several users :
User1 - fragging FPS game
User2 - Torrenting without app limiting download/upload speeds which potentially eat up all bandwidth.
User3 - same as above
User* - ...video streaming, FTP, normal file download....etc you get the idea.![]()
Nice. I assume your openwrt installation is on an x86 mini PC.
It will be interesting to compare the results without SQM on your openwrt installation. I tend to think it will still be A+ with your x86 based router and M1 500Mbps subscription.
yes. install on x64 mini pc.
dun think it's worth wasting time tuning it to get a A+
i've disabled SQM since actual usage there's no improvement at all
Thanks for the confirmation.
at least i have no issues playing netflix on 3 TVs at home tonight
4x webcam...constantly uploading to xiaoyi-css-sg-15d.oss-ap-southeast-1.aliyuncs.com
without visitors.. i have abt 16 devices only
i'm not a heavy user
