XIAOMI MI 11
ZhuTou!
Ya after go developer disable optimization, all permissions will reset
Need redo 1 by 1
Then ur UI will change also
Like font become diff etc
Last time i tried before but WA will still lag
Till i update framework version then solve it
Sent from Redmi 10X Pro using GAGT
aljj1996
Ytd got the shock of my life when i cannot update my app thru playstore. But when to check today after reboot, can update liao. Just received an update for Mi 11 12.0.22 so far so good.
TUV2008
Really getting sick of dealing with all the delayed notifications issue, is this unique problem of miui?
Need redo 1 by 1
JuXn5566
Global ROM should be no issue. Chinese ROM then will have this type of issue and sometimes notification don't even appear.
TUV2008
I have never tried to flash global rom on my China set, now with mi is shutting down GMS on China set May be is time for me to flash global rom.
Never done flashing of rom, does it affect all my app and content? Will there get wipe off all my content and I have to redo everything again?
Audiology93
Yes if u flash to global ROM, have to reinstall and setup everything again.
Sent from Xiaomi Mi 11 using GAGT
ZhuTou!
Now u know my pain lol
I tried so many ways and finally i get the correct solution
Why not u try my way by using android 10 framework?
At least no need to unlock bootloader to install rom
But of coz u need to forgo future miui update liao
I factory reset my phone before install so everything will wipe off except miui version
See u wanna try anot ba
Hailgod
one of the biggest problems of CN rom. i would personally never buy a xiaomi if there isnt global rom out.
johnsonheng
i heard that the cam app got special theme that provide a astropgoography background.
Pryson
Banking apps, gpay all works no issues but apart of the china Rom bloatware. Nothing much different.problem is weekly updates if you are on eu Rom requires you to update via fast boot everytime which I guess is a hassle to most of them.
aljj1996
wah yah i read that ota will be ready once TWRP is up for Mi 11 eurom. Does that mean need to root for TWRP?
Pryson
For those of you who get missed whatsapp notification. Disable the smartscene in scenario and reboot your phone. You will not have any miss notification thereafter.
TUV2008
Where to find smartscene and scenarios? I search in settings not found.
Sent from MI 10 PRO 版權@TUV2008 翻印必究 Lim Kopi using GAGT
