DBS digiportfolio
Kojo0403
why not just find a good etf to buy? returns are much better..
depends on how much an investor has.. it’s not really meaningful to DIY a less than 100k portfolio given its execution/ rebalancing etc.
a good 6 digit portfolio and above i agree that it does make sense to DIY using etf over the long run
then again brokerage fees have been coming down and there is low cost regular saving plan offered by DBS, iFast etc. so i agree it’s good for individual to start investing through these channel
yuzu28
wow how long did you hold for asia to reach 8 to 10%?
Iirc around 4 to 5 months on fast n furious 4. Seems like (hope I'm right), using robo also depends on timing. good timing then good returns. My stashaway and endowus both buy in dec, 30% risk, yield is only 1.x%. but stashaway is slightly better.
If u see what endowus and digiportfolio buy in, i somehow feel digi is better. Endowus seems simple and can diy easily. Under dbs, u can actually find some uts that other platforms (like poems, citi) dun have. Of course, citi also has some uts that dbs dun have.
dappermen
while Endowus is just as simple like another robo, it seemed to take so many days to update our app the returns .......why so long?!?!?!?
and it cannot take simple instruction, i told them i m holding off some of the cash/portfolios (pf) created , i m banging all my cash deposited on 8 feb onto a particular pf recently-created instead but they........just took all my cash and channel it into First in First Start ........what is the point of me emailing their staff directly??
till date nothing is updated
myhealthychoice
How much have you invested in digiportfolio? Any one chose the risk 3 for Asia portfolio and what is the yield now?
Nesunicorn
Good time to signup now?
Been reading being a noob and will like to signup one with dbs being the safest. Need to park money in for at least 3 years, I reckoned dbs being the safest bet.
Is now good time to enter?
Know we should not time the market but just wants to check the sentiments around if you all can help me with. Thanks
intime
You can try put in the initial $1000 first. then slowly every week or every month top up. :s22:
dappermen
If u r buying/picking a portfolio of more of uS stks/ global then the ans is not a bad time to enter.......
If sg-related stocks, prolly can wait or defer
lzjlee
My Asia portfolio risk lvl 4 drop 2.5% from last week.
lzjlee
Any idea what caused this?
Does Myanmar military coup has a part to play?
Actually I also not too sure. I see the portfolio holding is made up of Singapore, China n India.
The portfolio itself is quite volatile. Always up and down. Few weeks of small gain can get wipe out in days. So I also not too affected by the short term gain/loss. Hopefully will do ok in the longer term.
TehSi99
Seems Global portfolio is more stable but the fx rates....
vbhelper
being with digiportflio for 6 mths with 10k, during these 6 mths my invested amt will fluctuate around 10k. This is worst than fixed deposit rate
ahboy82
Wat risk n portfolio u chose? Moi one ard 10 to 12%per year returns
