ntuc gift card
digitalguy
bros i plan to get ntuc gift card using uob one card or dbs live fresh. is buying ntuc gift card or topping up of ntuc gift card eligible for cashback for uob one card or dbs live frsh card?
thanks
linuskltan
thanks
Purchase of NTUC FairPrice Gift Card is just like any FairPrice txn.
itachi2009
thanks
I just purchased the ntuc gift card with uob. Initially wanted to purchase the vouchers but oos. Have you confirmed you got your cashback for uob one?
maumu
yes it's eligible for cashback - it's just like any other transaction from ntuc fairprice...
hclee01
Just to share that there is a website to check NTUC giftcard value and expiry date:
https://www.vcsys.com/se/fairprice/p/
Looks like this is a better deal than getting the vouchers since the entire purchase can be deducted from the giftcard as compared to the vouchers.
CrashWire
Even better: the expiry date for the entire card's value gets extended by 1 year with every topup.
Imhthc
Yes. I have been topping up $200 every few weeks and the expiry date is automatically renewed from the date you top up. The txns are identical as a purchase with ntuc. However my card is ntuc finest so can use in finest only. Din know normal ntuc also got cards nowadays and not sure whether they are accepted by finest.
fr33d0m
NTUC ones are accepted in all NTUC, including Unity, I think.
CrashWire
I think Finest were the first to issue gift cards, then they decided to expand it to all of FairPrice. The cards should be usable at the normal branches too, if I'm not wrong.
Joseph99
Yes. All cards (be it finest or normal) can be used at all ntuc outlet.
revhappy
I am planning to get a NTUC gift card to fulfill the min spend for my new POSB everyday card. There is also a DBS Paylah promo for me, spend $250 and will get 8% cashback capped at $20. Might as well use this, since my monthly spend is so low, I mostly use credit cards which give like 2% general spend cash back only.
So I just go to the cashier and ask them for a gift card and then topup there?
Trazora
yes, gift card should be displayed at cashier already
hclee01
For the bigger stores like the NTUC Xtra, you can go to the Customer Service Desk to ask for the gift card and top-up on the spot.
chiokcc
Anyone using the Fairprice app?..
Any user experience comments?
