- Sep 16, 2018
Well considering it is one of the cheapest mesh wifi kits u can buy - u get what u pay for lah. it works well for me cos i have wired LAN backhaul
Yes Askey/Airities can be pretty okay if you can use Ethernet Backhaul.
But they may only be the cheapest if you need SingTel TV box support.
If no need SingTel TV support on the mesh node (you can still connect SingTel TV box to the ONR or the free SingTel router through wired connection), there are much cheaper solutions:
1) TP-Link Deco M4 AC1200: S$88 per pair now, usually S$99 per pair. Buy 2 pairs only S$176.
https://www.hachi.tech/biz-solution...routers/tp-link-deco-m4-2-pack--6935364084189
2) Deco M5 3-pack is better than M4 and only at S$198. Two pack at S$149.
https://www.hachi.tech/biz-solution...whole-home-wi-fi-system-3-pack--6935364080839
3) Huawei AX3 Pro+AX3 (AX3000): around S$85 + S$45 =S$130 or less.
If you can not use Ethernet backhaul, then you can consider Deco M9+ triband, two pack at S$258, only slightly more expensive than Askey/Airties.
https://www.hachi.tech/biz-solution...-fi-system-deco-m9-plus-2-pack--6935364083175
