iPhone 12 Series
qrcode
Just to check, are you using camera lens protector on your iPhone pro max?
Posted from PCWX using "World is inside the QR"
JayBeeLwashere
Initially didn’t used it but I had scratches on the frame surrounding it so have to cover up because it’s an eye sore. So far no issues.
Snoweagle
My iPhone 12 Pro Max still cannot use posb app as it will heat up the phone. I gotten a S21 to use the POSB app instead lol
Sent from Samsung SM-G991B Phantom Violet using GAGT
Wow you bought a S21 just for that?? :eek:
Zaalaa
Partially uh, getting very inconvenienced as I can't use POSB for paynow and stuff ... But part of me want to try Android also haha
How’s your Android experience? Any regrets? :s13:
kashix
swgj86
Anyone faced issues of the phone restarting (circular motion icon) when using WhatsApp or some other apps? It’s like a brief 1-2 seconds before it goes back to locked screen? Happened to me a few times this week when using WhatsApp.
Habrosus
eSIM with iPhone 12 Series
Has anyone faced any issue with eSIM for his/her iPhone 12 series?
Not sure if I should get the eSIM at the same time with the phone, or test it out first before ordering the eSIM. Any advice? :)
