ViewQwest Fiber Broadband Official Thread - Part 6
xonix
Viewqwest also switch to cgnat liao ? Must be why cheaper pricing for their 1gbps plan.
ZhuTou!
500mbps no router plan can opt for static ip paying extra 3.99 i think
I rmb is few dollar only
Sent from Redmi 10X Pro using GAGT
xonix
Personally not so concerned about static ip. Cgnat comes with it's own set of problems especially reliability & security based on what i read online.
trueworship
There was a scheduled maintenance today from 1-5am and the email says they will inform us when it is available. Till now there are no email from them and I can't access. Unable to call through as well...
trueworship
Update: after the maintenance, they forgot to assign me an IP. So if anyone encounter this - u will need to try your best to call in. (Manage to get through after 2 hrs)
jeffong
I had to swop out my ONU this morning as instructed and after that I noticed that I no longer have a static IP address. Anyone noticing this as well?
giraffey
Log in to the webconsole of the ONU (192.168.1.1). You can see it from there.
fyi.. The ONU configuration will show as DHCP. But your IP address will be fixed. Do a whatsmyip.com. Your IP address should still be the same as before.
jeffong
Already checked on this. My public IP matches the DHCP address shown on the ONU. Now beginning the long tedious wait to talk to their agent. Even my digital voice line also not working.
jasonho
Mine still show s a IP address 103.26.xxx.xxx . Guess i better dont reboot my router or ONU in case I lose it. :o
jeffong
Did you had to replace your ONU this morning after their 1 to 4am maintenance?
giraffey
Also had minor issues to after post-migration. Like yours, one of it is digital voice not working. The other was freedom vpn.
It was quickly resolved when I managed to connect to a technical agent.
giraffey
You should test it out. This is to confirm that the IP address is uniquely assigned to you and they don't "misconfigure" or "cheat". Maybe one of the nights, turn it off. Then turn it back on in the morning.
