OnePlus Nord
humble hoot
xonix
wah media tek
getting worser
Actually, if you are not a power user, their latest flagship dimensity chips are actually quite decent in performance for day to day tasks. For me, i prefer Snapdragon soc because they allow me to fall back on gcam ports as a plan B if stock cam sucks. No time to play custom ROM nowadays.
Shalomp
Then just get red mi or poco phone. They also use media tek and cheaper than nord
xonix
Haha true if only looking at price, xiaomi definitely more bang for buck.
But at least for the time being, I will still take oxygen os over miui anyday ;)
limmk
https://9to5google.com/2021/08/23/o...-for-oneplus-nord-w-august-patch-bitmoji-aod/
OxygenOS 11.1.5.5 for OnePlus Nord update changelog​
  • System
    • Updated Android security patch to 2021.08
    • Improved system stability
  • Ambient Display
    • Newly added the screenshot feature for AOD
    • Newly added Bitmoji AOD, co-designed with Snapchat, which will liven up the ambient display with your personal Bitmoji avatar. Your avatar will update throughout the day based on your activity and things happening around you ( Path: Settings – Customization – Clock on ambient display – Bitmoji )
Mr_Farmer
Reposting for convenience. To enable volte for oneplus devices:
Guide to enable VoLTE
1. Download these 4 files:
QPST (Install on PC) - https://qpsttool.com/qpst-tool-v2-7-474
Qualcomm Driver (Install on PC, select WWAN option) - https://androidfilehost.com/?fid=11410963190603864074
Oneplus logkit (Install on phone) - https://forum.xda-developers.com/attachment.php?attachmentid=4763657&d=1558542807
Oneplus Engineering Mode (Install on phone) - https://www.apkmirror.com/apk/onepl...-0-171117173719-25c8842-android-apk-download/
2. Install the files as mentioned on PC/Phone
3. At phone dialer, key in *#800# > oneplus logkit > Function Switch > Tick "VoLTE Switch"
4. Reboot the phone
5. At phone dialer, key in *#801# > Engineering mode > ON "Full-port Switch"
6. Launch PDC Software on your PC
7. Select the Qualcomm WWAN Adapter
8. Right Click "Oversea-Commercial_DS", deactivate Sub0/Sub1 (Sub0 is SIM1, Sub1 is SIM2)
For me, M1 sim is in Sub0, so i only deactivate Sub0
9. Scroll down, and find and Right Click India-VoLTE-Vodafone > Set SetSelectedConfig > Sub0/Sub1
10. Once done, click on the Activate button below to activate the VoLTE Profile
11. Reboot your phone
12. Go to your Settings Wi-Fi & Internet > SIM & network > SIM 1/2 > Toggle on VoLTE
13. If everything is successful, the VoLTE icon will appear on status bar
Disclaimer: Try it on your own risk, dont claim from me if your phone up lorry :s13:
Hi Hi, I'm unable to install the logkit as it conflicts with another and when i enter *#800#, the Feedback app comes up instead. any advise?
KeYoKe
Not sure bro. This guide is ages ago. Oneplus might have changed the software since then. And i dont have old phone to test already bro
