Obtaining recommendations for Building a new rig.
TheCorgi
Motherboard died from my 2014 rig.
Just going to use the old HDD and everything else new.
Budget is 1,000.
Light gaming like L4D2, watching videos on two monitors. Would prefer a strong processor for applications like photoshop etc.
Please advise, thanks in advance.
NightRaven49
wah building when old pc die quite sian, especially now when u cant get any reasonably priced gpu. do u have a dedicated gpu u can reuse from your old rig? if not, then maybe might have to get intel so that u can run off integrated graphics. ryzen with integrated graphics isnt really a good substitute because official retail models are at latest only based on zen+ (3200g/3400g etc), which are considerably slower. if u are willing to take a risk, u can go to online vendors for zen 2 based oem (non retail) parts, which are decently performing but are hard to find and not always in stock.
soltrdc
Bring your HDD to SLS shop, tell them you want a new PC with $1k budget and reuse your HDD.
Richliao
Actually he just needs to buy mobo and processor and maybe ram so it's not that bad.
NightRaven49
thats basically half a pc already :s13: also need to consider if u buy the processor whether if have integrated graphics, which is basically my previous post.
Goodshot
$1000 only get u basic desktop. If need photoshop should be around 1.5k above
And worst now gfx card price all increase like hell
Koenig168
^^^ this
+ an SSD if necessary
$1K is not sufficient for a new rig in the present market unless OP does not need a GPU. Even second-hand GPUs are asking for high prices.
TheCorgi
I have a GTX 750 Ti which should still be in working order. Not sure its compatibility with a new motherboard ?
TheCorgi
Sorry forget about the photoshop. I can drop that.
Another application that I use fairly often and I extracted from their system requirements: "modern 64-bit CPU (for comfortable usage i5/i7 quad or equivalent is recommended but we tested on older quads as well and it will work just slower (anywhere from 2x to 5x slower))"
Probably need some advice on a pairing of processor + mobo.
acertey
Hi sorry to jump in, was in the same state and finally decided to get a RX6700XT or a RTX 3060.
Below setup is about 2.6k, any thoughts or sharing if this is good build. Planning to upgrade my monitor also maybe 6 months later
ItemBrandModel
MotherboardAsusMSI B550M MAG MORTAR WIFI
ProcessorAMDRyzen 5 5600X
PSUSuper FlowerLEADEX III 80 PLUS Gold Full Modular 750W
RAMCrucialBallistix 3600 MHz DDR4 8GBX2 CL16
CaseFractal DesignBeQuiet PureBase 500 PC Case, Meshify C
GraphicsGigabyteRadeon RX 6700 XT
SSDSamsung500gb Samsung 970 Evo plus m.2 nvme ssd
HDDToshiba2 TB
CPU CoolerMSI240mm liquid cooler
Koenig168
ItemBrandModel
HDDToshiba2 TB
Looks pretty good. For the AIO, you can consider the MSI MAG CORELIQUID 240R
acertey
thanks bro, yeah was planning to do that. :)
Actually between RX3060 and RX6700 XT would there be any preference?
NightRaven49
if both cost about the same, then go with the 6700xt. the 6700xt offers a lot more performance.
also another place i suggest u can save is with the ram, 3600c16 ram is a good bin but u pay a hefty premium for it. just get regular 3600c18 ram and tighten the timings from there.
acertey
Gigabyte Radeon RX 6700 XT GAMING OC($1299),
Asus RX 6700 XT Founder Edition($1299),
XFX RX 6700 XT($1149)
Any thoughts on the above in terms of performance? Was a little more inclined to Gigabyte.
NightRaven49
navi 22 is already pushing the limits in terms of clockspeeds, and factory oc cards dont usually have more than 5% performance advantage over stock cards, so i would say just get the cheapest, since paying $150 extra (~10% premium) on the gigabyte one vs the xfx reference for such a small bump in performance with probably no more oc headroom is not really that value. xfx is a good amd exclusive aib like sapphire, so i dont think youll go wrong with it.
congster2
if I were you, I would like do a quick check on the cooling capacities of the different models + consider the warranty. if cooling is about the same, and warranty is about the same, then pick the cheapest. Nowadays, higher performing cards are mostly a matter of silicon lottery. Better to just assume they perform about the same.
