Pocophone X3 Pro
ceestudent
Bought 1 unit of Poco F3 8GB/256GB black when it was up cuz it was 'cheap'.
But, not really sure what to do with it cuz i dont really need a new phone.
Anyway, the corners cut on this device are the camera, wireless charging and display resolution, in-screen fingerprint sensor. Overall, all pretty acceptable areas to cut to reach the price point.
I am not dinging the display, its already a good one for the price but i am used WQHD+.
You can just sell it at cost at carousell. Should be able to find buyer very fast.
Skyy
Small tips when you use TPU case, don't rub it with alcohol wipe. It will make scrub off the outer layer and end up your case become whitish very fast.
oh really? I use alcohol on my TPU cases all the time cos it's oily from usage, never had a clear TPU case turn white b4. I have seen clear TPU cases turn yellow though
LobsterX
same. i use the alcohol wipes to clean my clear tpu case after i replace my screen protector.... dunno why keep chipping at same spot. no keys, no hard objects [ahem... that one although hard, but cannot be the cause of the chip]
now have see where to buy a nice clear case to fit my phone in so the screen sits below the sides of the case...
xenocide
Not really. Is just the waiting part to unlock bootloader is long
You can always flash back miui and lock back the bootloader
is the requirements still same?
the last i did a bootloader unlock was for MiMix2
ceestudent
Not really become white color like milk, but it looks cloudy and not so transparent. And the inner part become stick to the phone after you wipe it.
Usually i wash it with soap instead, else with wet tissue.
Anyway if you find it okay then good for you. Maybe the case i bought not so good quality.
