Pocophone F3
Devilsire
Poco F3 thread to avoid merged discussion with X3 Pro
xenocide
Nice! thanks!
Lets share all cases and accessories.
Also share shipping details and 1st hand receiving and unboxing if possible
Case i bought:
https://shopee.sg/product/309405760/8630601081
Issues with Dual Apps not able to access storage credit: @garychengjw
Tips and Tricks:
1. WhatsApp contacts name. credit @ZhuTou!
Go to WA permission
Allow Modify and delete contact
And Read contact
Then refresh ur WA contact
2. Gmail Sync. credit @anizee
For the Gmail, after enabling autostart and disabling battery saver, I also went into the Gmail app > Settings > General Settings > Manage notifications and then I enabled notifications manually for my Mails. That did the trick for me
3. Missed notifications for whatsapp. telegram. credits @KeYoKe
whatsapp, telegram can enable auto start and disable battery saver
4. The miui optimisation missing for installing of youtube vanced. credit @KeYoKe, @Hailgod
Go Settings> Additional Settings > Developer Options > Reset to Default value.
After installing, go to playstore and uninstall youtube. afterwards you can use other apps to open links directly to vanced
5. (USE AT YOUR OWN RISK!!!) Debloat Tool (USE AT YOUR OWN RISK!!!) credit @KeYoKe
If accidentally remove, and phone stuck in boot loop, boot to recovery by:
1. Power off phone
2. Press and hold Vol Up + Power button to boot to recovery mode
3. Wipe Data + Cache
4. Reboot phone and you will need to re-set up your phone again
6. Or you can follow this link here to remove/uninstall apps using the Tool above. AGAIN TRY AT YOUR OWN RISK! BACKUP! BACKUP! BACKUP!
7. Gestures with 3rd party launchers (Work around). credit @Hailgod
8. Ads blocking via Blokada. credits @Skyy
For those using Blokada to block ads, it won't work by default. Need to go to the phone Settings, search for Private DNS and turn it to OFF. Then for maximum ad blocking, in Blokada ver 5, go to the Advanced tab (the icon looks like a cube), then click Goodbye Ads, then choose the Xiaomi blocklist. Rem to also set Blokada to Autostart, No restrictions in Battery Saver and lock the app in the Recents page
9. Battery drain issue work around. credit: @KeYoKe
those with battery drain issue, try this:
Settings > Apps > Manage apps > Top Right Corner 3 dot > Show system services > Battery and performance > Clear all data
Once done then reboot your phone and monitor
10. How to force 90Hz refresh rate. credits: @KeYoKe
11. How to "force" update a downloaded update file *** TRY AT YOUR OWN RISL ***
For those whom cant see the update, download the update file
https://bigota.d.miui.com/V12.5.1.0...RKHMIXM-V12.5.1.0.RKHMIXM-3ed74948a7-11.0.zip
Then go to Settings, About Phone, MIUI 12 Logo > Click on the 12 icon till u see additional features turned on
Top right corner 3 dot and select choose udpate package, and select the update file downloaded
xenocide
Devilsire
if im not wrong all F3 yet to ship.
no complains since its stated upfront being 5days pre-order, probably awaiting factory to churn out the fresh stocks. Its stated to ship by 2 April tho
Skyy
has anyone's F3 shipped out? i thought i saw in the morning they set it "Seller is ready to ship your order", then just now i checked, back to nothing...
KeYoKe
Not yet.. think they are still clearing x3 pro orders
