Hi, I moved to Singapore not long time ago. I am really into vintage Levis jeans. Where can I find real vintage stuffs in Singapore? Thanks.
Any idea where can I get Iron Heart Jeans in Singapore ?
Thanks.
Don’t think can buy IH in Singapore.
Just online buy it, I think most of us just order online.
Noted but worried only on the size and also I believe need to pay 7% gst because price most probably exceed S$400.
Sizing is a skill you need to learn for this hobby haha.
My first couple of pairs also not the best sizing and fit, extreme light oz to heavy oz jeans might need adjust a bit also. Loose or tight weave also need to adjust a bit.
But yep, it’s all part of the journey.
If I am wearing a size 36 for my Samurai Jeans, can I also order the same size for my IH ?
You need to do measurement (waist, thigh, knee, rise, leg opening, etc) comparison of both your current pair and the pair you want to buy.
Then +- based on other factors.
If the shrinkage percentage is the same for both Samurai Jeans and IH Jeans, then can I just base on my current Samurai Jeans size to buy if it's the same cutting with my current S710XXX ?
for me now personally i prefer slim fit from waist to knee, and then skinny fit/tapered from knee down to the opening.
i like the opening to "hug" your ankle. so usually need to tapered outside
As mentioned need to compared all those measurements if you want to be accurate. Most sites will list down each size measurements...
Been away for denim for more than 10 years. Only started wearing more now due to WFH and semi casual attire.
Decided to hoot momotaro 0701 from Okayama denim. Just not sure if I screwed up my size.
The measurements of my waist with pants on at 86cm and the pair I bought was tagged size 33 which measures 83.5cm. I decided to go for one wash fabric cause the unsanforized raw process just too painful for me now. Gained quite a bit of weight over the years so naturally I was a 32 and decided to size up 1. Initially was thinking of sizing up 2 but changed my mind.
If it really doesn’t fit then I guess I must return.
Any good denim alteration shops to recommend?
